The writing on the screen is stretched beyond the width of the screen and I lose script on either side - I have checked the fine tuner on the remote but it doesn't seem to have the ability to fix the problem
  • 78 Answers
If you have a wide flatscreen tv it could be that the picture size is in the wrong mode. under the mode button on your tv remote should be two buttons labeled wide and zoom. try pushing these buttons to adjust the tv screen size.
Posted on May 02, 2008
What features does a apex tv gt3215 have?
GENERAL
  • TV typeCRT TV
  • Screen size
    32 in
  • Power Consumption Operational
    150 Watt
  • Timer Functions
    Sleep, wake
  • Video Interface
    Composite, S-Video
  • Manufacturer
    Apex Digital, Inc.
FEATURES
  • TV features
    auto volume adjustment
VIDEO
  • Technology
    CRT
  • Aspect ratio
    4:3
TV TUNER
  • TV tuner presence
    Yes
  • Analog TV tuner
    NTSC
  • Reception System
    NTSC-M
  • Secondary Audio Programme (SAP)
    Yes
  • Secondary Audio Program (SAP)
    Yes
  • Channel Coverage
    VHF:2-13, UHF:14-69, Cable:1-125
  • Stereo Reception System
    MTS
AUDIO
  • Speaker(s)
    2 x main channel speaker - built-in - 5 Watt
  • Output Power / Total
    10 Watt
  • Audio Controls
    sound mode
CONNECTIVITY
  • Video interface
    composite
REMOTE CONTROL
  • Type
    universal remote control
  • Supported Devices
    DVD player
CONVENIENCE
  • Closed Caption Capability
    Yes
  • Parental Channel Lock
    Yes
  • V-Chip Control
    Yes
  • Menu language
    Spanish
MANUFACTURER WARRANTY
  • Service & support
    1 year warranty
POWER
  • Nominal Voltage
    AC 120 V
  • Power consumption operational
    150 Watt
DIMENSIONS & WEIGHT
  • Weight
    156.5 lbs
DIMENSIONS & WEIGHT (SHIPPING)
  • Width
    38.7 in
  • Depth
    29.2 in
  • Height
    30.5 in
  • Width (Shipping)
    38.7 in
GENERAL
  • Manufacturer
    Apex Digital, Inc.
Mar 08, 2014 | Televison & Video
The text along the sides of the tv screen are not completely in view
you need to change the 'zoom' on the tv by the remote.
Normal mode frames the 4:3 video to the 16:9 picture area by displaying it in its original aspect ratio, with vertical gray or black bars on both sides of the screen. The disadvantage of this method is the fact that the image is small by virtue of not using the entire width of the screen. This is also known as the 4:3 mode.
Full mode Full mode horizontally stretches the 4:3 video evenly across the entire width of the screen. This is the proper mode to display anamorphic video. If used for standard aspect ratio video, everything on the screen will appear wider than normal. Contrast this with anamorphic video displayed without processing on a 4:3 display, in which people on the screen will appear taller than normal. This is also known as the 16:9 mode.
Zoom mode Zoom mode evenly stretches the picture both horizontally and vertically, until the picture fills the entire width of the screen. This crops out the top and bottom of the picture. This mode is used for letterboxed and open matte video.
14:9 mode Main article: 14:9
In 14:9 mode, the picture is magnified more than in Normal mode, but less than in Zoom mode, while retaining the original aspect ratio.
Wide Zoom mode Wide Zoom mode, also called Just mode, Horizon, or Smart Stretch, progressively stretches the picture horizontally, less in the middle and more on the edges. This allows normal aspect ratio video to be displayed across the entire width of the screen, with minimal cropping, and with much less of the unpleasing visual stretching effect of Full mode.
Dec 08, 2013 | Emerson LC320EM9 32 in. LCD HDTV
My TV picture keeps stretching beyond the screen. Can I adjust it?
Some sets and some CABLE OR SAT BOXES also have a feature where you can adjust height or width of the picture--look carefully in both units menus to see if you have it.
Mar 30, 2012 | Televison & Video
Horizontal image is stretched beyond the screen borders
the problem is inside your TV , check the capacitor in vertical section of the TV.
Jul 31, 2009 | Apex Digital PF3220 32" TV
Screen size
well you will have to see what you can do to clean up the remotes contacts, use a little baking soda and water to clean out the inside with a towel and then clean up the contact surface of the spring and the flat side, cleaning off the rust and acid burn should give you enough contact to get a good pair of Duracell's to work and you can remote the stretch off.
it is imperative to get the remote working, even if some one needs to rebuild the contact area from old parts from some other device with batteries.
Mar 26, 2009 | Akai LCT2715 27 in. LCD Television
Picture stretching beyond he edge of the screen
One of the more common reasons a TV has part of the picture off the screen is due to an incompatible screen format or aspect.
Check to see if there is a format or aspect button on the remote or if these options are available in the menu.
If so, then try a different format as one may work better for what you are watching.
Aug 20, 2008 | Televison & Video
HOrizontal width problem
With older sets i found dust as the main culprit in simmular situations.check for any  adjustment pot on the circiut controlling the screen width[normaly 3 pots close together open back of set to reveal electronic's]. be very carefull not being electrified as the set must be in operation while doing the adjustment.even turning the pot forward and back and then to the original position sometimes solve the problem.
Oct 17, 2007 | Televison & Video
Screen Widens Out Constantly
you might be getting more supply from regulated power supply if you get wide pictureor width have to be adjusted by width control. but if it stretchs out & lose some of the picture on the right and left edges it might be due to horizontal output section. 1 loose contact in connector. 2 some capacitor might be defective in h/section caution please do not open the set unless you know about high voltage in tv set.
Sep 16, 2007 | Emerson EWF2703 27" TV
Distortions in sides
Sounds like you might be in the panoramic display mode... check your remote for a button labelled "WIDE" - it's on the left side just below the "GUIDE" button. Hitting WIDE will cycle through the various viewing modes (normal, zoom and panoramic).
Aug 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
