Question about HP PSC 1410 All-In-One InkJet Printer
Scanned copy cannot be saved
I have a HP PSC 1400 All in One scanner-copier-printer
I use both HPscanning and microsoft document image scanning (mdi) to scan documents and save them to my word file as pdf from HP and mdi from mdi. I have been doing this for over 2 years now, without any problem. From yesterday, I find that the document gets scanned in mdi but an error message comes when I try to save it as a file. The scanned image also disappears.There is no problem with HP.
I have repair/installed my MSOffice03 but there is no improvement. When I put in the driver (CD version 7.2.2-/ Q7286-10008) supplied with the scanner, I get a message "Put in All in One CD" or something like that. How do I proceed? Please advise
    Problem Solver:
  • 12 Answers
Try to downlaod the software from HP.com
Posted on May 02, 2008
How do I scan a document using the hp psc 1315 and then find it on my computer? I press the scan button and it seems to scan, but then I can't find the newly-scanned document anywhere. There needs to be an...
The scan button is setup to push the scan to an application, if you uninstalled the HP scanning software, it isn't going to go anywhere. If you didn't, it will put it into your documents folder under "My Pictures" in an HP created folder.
That said, you can also go into any application, like Word. then click "Insert > Picture > From Scanner or Camera" and carry the image in directly.
Oct 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
How do I Scan a doucment with my HP PSC 1315 All-In-One InkJet
Sir,
open HP director click SCAN DOCUMENT set scan for editable text YES set original contains graphics NO if it doesn't, YES if it does (no results in smaller file) if you want to create a PDF file, leave SCAN TO set to SAVE TO FILE if you want to create a word document, change SCAN TO to MICROSOFT WORD click SCAN click ACCEPT (bottom right) tell it NO if you're done, YES if you want to scan something else If you scan more than one thing all of your scans will end up in a single multi-page file rename & save file to permanent location as you would normally.
Good Luck
Aug 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
My psc 1610 scanner function is not working, the output was totally in black while scanning a document
My HP Psc 1610 all in one can print & copy but can't scan. I already installed the driver for Windows 7
Jul 09, 2009 | HP PSC 1610 All-In-One InkJet Printer
I need to scan a document from the printer (HP psc 950) to my PC
If you are using a Win Xp computer than try to scan using scanners and cameras utility under control panel. Else you can download HP scan drivers and perform scanning. Also 3rd party scan softwares such as photo shop will allow you to  scan.
Jan 22, 2009 | HP PSC 950 All-In-One InkJet Printer
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
Hp psc 1100/1200 all-in-one does not scan with vista..
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
Aug 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scanner
Please help me figure out why my Hp PCS 1410v won't scan
Jul 02, 2008 | HP PSC 1410v All-in-One Printer
HP PSC 1410
Hi ,
Please follow the below procedure to scan a document.
  1. Connect the scanner to the computer
  2. Install the software with the help of CD which you get from hardware manufacturer
  3. Open the Lid of scanner, Place the document you want to scan
  4. Close the Lid after placing document
  5. Open HP software which you have installed above, click scan now ( or any thing similar )
  6. Scanner will start scanning you can hear the sound and strong light rays passing through the document
  7. After this it creates a soft copy
  8. Save the file , by default is get saved in my documents you can save any where else if you want
  9. For better results veiw soft copy in PDF that is acrobat reader.
Hope this answers your post, Please let me know by providing your valuable feed back
Thanks,
Robosoft
Dec 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
Hp psc 950 from scanner to pc save
I was having the same problem when I pressed the "Scanner" and then "PC Save" buttons. But I found that if you have the printer software installed on your PC, you can double-click on the printer icon that should be on your desktop, and a window will come up where you can scan, copy & view images, etc. Hope that helps.
Dec 24, 2006 | HP PSC 950 All-In-One InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
181 people viewed this question
Ben Johnson
