Linksys voip spa3102 through Zyxel g-302v3 I am uable to get a conecction I have tried severa IP addresses to no avail how do I cofigure either one of them to make them compatible
    Genius:
  • 1,226 Answers
Do not use ip set your pc/laptop to automatically obtain IP address.
also uninstall and reinstall the network driver of your computer.
may thi shelp,
melnavz
Posted on May 02, 2008
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE and go through all the steps mentioned.It will help you fix the problem.
Goodluck,
Please don't forget to rate the solution
I have a ZyXEL EQ-660R-F1 and a Linksys Wireless Router (B BEFW1154) that I'm trying to hook up. Can you tell me what I need to do?
Who is your ISP (internet service provider)? Anyway, it is possible to get your set up working. ZyXel is the DSL modem gateway and Linksys, your router/wifi. If you are able to get online by hooking up directly to the Zyxel, then it is possible to add the Linksys to the system.
Dont hook up the Zyxel to the Internet port of Linksys just yet. First you have to configure the Linksys by connecting your PC to it with a cable. Boot up the PC.
Open web browser and enter the address 192.168.1.1 and hit enter. This is the default address of the Linksys. username = admin and no password. It is probably the same as the Zyxel which causes the conflict.
The first set up page may look something like this below.
Change the LAN IP address from 192.168.1.1 to 192.168.2.1
Then click apply...From now on the Linksys IP address is 192.168.2.1.
Now you can connect the Linksys internet port to the Zyxel. Reboot the Linksys and Zyxel.
Your PC should be on the internet after that. To check/setup wifi, you need to log back into the Linksys using the new adress x.x.2.1
Feb 15, 2013 | Zyxel Prestige 660R Router (91004397002)
Linksys spa2102 i forget the password
Okay here is what you need to do.
try username : user
password : 1234
or
dial ****73738#
if it asks for a password use 8995523# or 7756112# or 5465866# or 50274537# or 78196365# (one of these numbers should work for you)
Hang up.
to check your linksys pap2 IP:
Pick up the phone dial ****110# The voice will tell you the current IP address. Write it down. Now you put that IP address in your browser and you should be able to get into your box type
http://192.168.1.103(for example)/admin/advance
Press enter.
Feb 04, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
Aug 10, 2009 | Linksys SPA922 IP Phone
Cannot connect it to Linksys wireless router.
try setting it up for DHCP and let it obtain its on IP address from the router.
May 29, 2009 | Zyxel Prestige 660M (P-660M-61)...
IP ADDRESS OF VOIP PHONE ADAPTER 2 PORT PAP2NA
doanload colosoft netscan, when you have it plugged into the network, run netscan on a computer thats on the same network....that'll find it for you, if that doesnt work give me the specs on the phone and ill check the manuels..
Jan 22, 2009 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
I have one desktop connected,I'm trying to connect the 2nd pc. They either both are offline, or by unplugging the 2nd I can get the first one online. In short, I'm trying to add a 2nd pc but somehow am...
are your linksys router are cofigured and the ip address was regestered to the AP?
if it is....check your pc by pinging the ip addres...
click start menu..
type cmd in the box..
type ipconfig to know the ip address..
after that ping the ip..
Jul 27, 2008 | Computers & Internet
My Linksys doesnt conecctin my other pc.
Make sure
  1. Your IP addresses are in the same subnet
  2. that the default gateway address is correct with the other computer
please try and get back to me and let me know the results..
Cheers
Jan 09, 2008 | Linksys WRT300N Wireless Router
Cannot access the internet through my DIR-625
Check your IP address to 192.168.10.1 on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
Nov 05, 2007 | D-Link DIR-625 (790069292637) Wireless...
Computers & Internet Logo
David Payne
David Payne
