Question about Saeco Incanto Classic Espresso Machine
Saeco Incanto - Water Light will not reset
I have found an answer in relation to the magnet in the water resevoir, however this is not my problem. Yes the water light does not reset, however if I run the steam for a while it does eventually reset. Once this has reset I can press the button for a shot of coffe and the unit grinds and packs the coffee, however when it then tries to brew the machine sounds like it is tryign really hard to push water through the pipes but just can't. Eventually it just gives up and the water light then comes back on. The cofee grounds then get dumped and are wet, however they are very loose and not the normal "puck" that usually gets dumped out. Any ideas on what may be the problem??. To me it seems that there may be a blockage in the water lines, however the fact the the coffee grounds are wet does not support this theory.
  • 487 Answers
Actually it sounds like a blocked filter from the brew group.
Take out the brewgroup and iether with your key (sometimes not in the box) or with an allan head remove the filter.
Check the filter by holding it against the light for obstructions.
Clean with needle
I guess this might well be your problem
And if you use hot water by the way instead of steam the water light will go out faster.
If your warm water works you have no problem with your boiler
Posted on May 05, 2008
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
Our Saeco Incanto Deluxe keeps saying "fill water tank" on the lcd screen but the tank is full. I remove the tank and put it back on then it leaks in the area of the hole where the tank sit in. ...
Does not sound like the seal. A bad seal would leak outside the machine.
The cause usually is the magnet in the water tank. Make sure that the magnet is floating when the tank has water in it. Click here to see what it looks like.
Hope this helps.
May 23, 2011 | Saeco Incanto Classic Espresso Machine
My Saeco Incanto Deluxe keeps giving a message "Fill Water tank" even though the water tank is full. Does not allow me to choose any other options. Please Help.
Your machine has a magnet that floats in the water tank. If the magnet is not floating when you have water in the tank then you need to replace the magnet. You can also try to clean the magnet before replacing. It may be dirty and tends to stick to the water tank.
This is what it looks like. http://www.cerinicoffee.com/item.asp?PID=1318
May 15, 2011 | Saeco Vienna De Luxe Espresso Machine
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
800-933-7876
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
3 flashing lights stay on all the time?
I have the same problem. It seems that the group motor issues. I ve opened up and found the group motor is coming some sparks. I know very well Saeco Magic Cappucino , Saeco range is more or less the same, Saeco incanto, first time deal with it , somebody just brought it to me to check it. I might fix it if find parts for it.
Load circuit means a lot, flow meter, pomps, could be the electronc board, bewing unit blocked up with coffee, so basically there is no water in circuit water or is air in water circuit....You have to check everything,
Mar 01, 2009 | Saeco Incanto Coffee Maker
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Water fill light stuck on
you say our fill the water light stay on lot they put a magnet in the water container fill it with water and gently tap the water container if the magnet stuck that should do it if it persite the magnet receiver under the cover is diffective normaly a few little tap do the trick
thanks for using fixya
pierre
Feb 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto classic
Fille the water tank and let it continue. It will stop before the next tank runs out
Feb 15, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
385 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
