Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor goes dark over and over
Here is my solution:
Around the time it happened I did a few things to my computer.
I had been trying NOD, it ran out - so I removed the program. When I did that my McAfee was gone. So, I had to go through their web help to get it back. It didn't want to just download again through their site. I had put in a trial version of Microsoft Office 2007. After I got that all done my java wouldn't work for yahoo games. All this was within a few days of each other, even the darkening of the screen, over and over.
Tonight, I noticed on my newly added McAfee, has a registry cleaner. So I used it. I also went into my program file folders and saw that NOD was still in there - deleted it and a couple of other programs that I had tried once, but, thought they had been removed through the remove programs, in the control panel.
My Monitor screen works fine and I was going to spend 200 on a new monitor.
  • Anonymous Jun 13, 2008
    I have the Dell E153FP Flat Panel monitor. As of past several days, the screen will light up when PC is booted but quickly goes dark. If I turn off the monitor and switch it back on, the screen will again come to life and then go dark again within 10 seconds. After repeating this off/on sequence numerous times, the screen will eventually remain functional...unless the PC is shut down. Upon reboot, i.e. the next morning...the monitor behaves as described above.
    President:
  • 2,712 Answers
Well done! Maybe you should think of joining the Fixya team :)
Cheers,
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    Thank you for using FIXYA!
    IrishDruid
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes dark
If the power light turns yellow, there is no signal being received by the monitor from your computer's graphics card. The screen will shut off (go into idle mode), which is a low-power state, that saves energy. Check that the cable on the back of your computer is plugged into the right graphics card (many PCs come with more than one, these days). There may be one built into the computer's mainboard, and another one may be on a separate graphics card located somewhere else on the machine. Only one of these will work on startup. If one doesn't work, try the other.
Apr 23, 2010 | Dell E176FP 17" LCD Monitor
Screen only works for 3 seconds then goes dark.
Capcitors in the power supply will be the first thing to check, see examples of what goes out in monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Mar 25, 2010 | Westinghouse Electric L1916HW 19" Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Screen goes pink and green starting with a few pixels
Best thing to do, try a different known working monitor to hook up to the computer. If the screen works and doesn't change colors then you know its the original monitor that is bad.
If you hook up the known working monitor and the same problem happens then you know its the video card that is bad and the video card would have to be replaced.
Aug 23, 2009 | ASUS VW222U Monitor
Flat Panel LCD Monitor goes dark for 2 sec then back on
sounds like the backlite bulb is failing. best thing to do is to take it in and have it checked if is worth the cost. some can be replaced, some cant.
Jun 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Comes on for about five seconds and then goes dark
MAKE SURE THE CONNECTION BETWEEN YOUR MONITOR AND YOUR COMPUTER IS PLUGGED IN TIGHTLY AND CORRECTLY, YOU MIGHT NEED A NEW POWER CABLE OR A NEW CABLE THAT CONNECTS FROM YOUR MONITOR TO YOUR COMPUTER, TRY CONNECTING YOUR MONITOR ON ITS OWN PLUG, OR IN ANOTHER SOCKET AROUND THE HOUSE IT MIGHT NOT BE GETTING ENOGH POWER, IF IT IS NOT LCD MONITOR (NOT FLAT) THEN YOUR COMPUTERS BULB MIGHT CIRCUT WRONG
Feb 20, 2008 | Liquid Video L17LCD2 17" Flat Panel LCD...
Dell E173FP 17" LCD Flat Panel Monitor Logo
66 people viewed this question
Alun Cox
