Question about Toshiba Satellite A100-S8111TD Notebook
Keyborad replacement I need to replace a keyboard on Toshiba Satellite A100 model # PSAA8A-05R010
    President:
  • 2,712 Answers
HERE is an article that will help. Although its fro HP, it is generic, and can be used as a guideline for any laptops.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
What did toschiba satelite 8100 lap top model number psaane/03j02gen transpose to
The Model Name and Model Number is Satellite A100-033.
It's one of the Satellite A100 series of Notebook PC's.
http://icecat.com.ua/en/p/toshiba/psaane-03j02gen/notebooks-laptops-satellite-a100-033-796649.html
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
3) Free Service Manual for the Toshiba Satellite A100 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the line that starts with Satellite A10. Scroll across, and click on A100.
This is a PDF file.
It may take up to 30 seconds before the first page comes up. It may also take additional time to fully download
{Service Manual for your daughter's laptop. I gave a solution to another one of your posted problems}
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Toshiba Computers & Internet
How do I remove and replace the keyboard on my satelite A 120 laptop. Can I have some instructions please.
Step one: Remove the two screws from the bottom of the computer that are holding down the Toshiba Satellite A100-S8111TD Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Toshiba Satellite A100-S8111TD Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Toshiba Laptop Keyboard.
Final step: To insert the new Toshiba Satellite A100-S8111TD Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Toshiba Satellite A100-S8111TD Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
G33k
May 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
HOW DO YOU TURN LIGHT BENEATH KEYBOARD ON TOSHIBA A660/07T
I'm not sure what model you have I do not see a A660/07T.
Here is a listing of the different models that have an LED Backlit keyboard. http://us.toshiba.com/computers/laptops/satellite/A660/available-models?EXTRAS=LED+Backlit+Keyboard&SERIES=A660&SUBBRAND=Satellite%26reg%3B&Ns=pUnitsSold'1&sms_ss=email&at_xt=4cddcae4e07d677f,0
Mar 05, 2011 | Toshiba Satellite A100-S8111TD Notebook
KEYS 9, O, L, AND . CANNOT BE PRESSED IN LOWER CASE.HOW TO REPAIR?
This sounds like a problem with the keyboard itself. Laptop keyboards are somewhat difficult to repair. However, fortunately they're usually easy to replace.
I found a new keyboard for your pc on ebay at the following address:
http://shop.ebay.com/i.html?_nkw=Toshiba+Satellite+A100-S2311TD+keyboard&_sacat=0&_odkw=Toshiba+Satellite+A100-S2311TD+PC+Notebook+keyboard&_osacat=0&_trksid=p3286.c0.m270.l1313
Generally laptop keyboards can be swapped out by prying off the plastic trim at the top of the keyboard. It's usually just snapped into place. This will typically reveal several screws holding down the keyboard. Remove these screws and carefully lift out the old keyboard. You'll see a ribbon cable coming off the back of the keyboard and plugging into a socket. Remove this cable. Sometime this is done by just pulling up on the connector and sometimes there
Sep 28, 2010 | Toshiba Satellite A100-S2311TD Notebook
All of a sudden, my underscore or zero won't work, neither will the hyphen ??
you might need to have your keyboard replaced.
or try to disassemble keyboard and reseat the flex cable of the keyboard to the board. if still doesnt work then most likely you need a new keyboard
Nov 12, 2009 | Toshiba Satellite A100-S8111TD Notebook
Fn key not working in toshipa laptop its model is satellite a505
Hello, Dody.
Give this a try: lift the key slightly, but enough to spray compressed air underneath. There may be debris under the key. Hopefully, that will resolve your problem.
If not, you may need to replace the keyboard.
Nov 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Not all keys working on keyboard
Try reinstalling the keyboard model drivers. If they are still not working, there may be a break in the wire. If you are using wireless, replace the batteries with some alkaline batteries.
Apr 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
New keyboard
Check out the following information on how to replace keyboards on Toshiba laptops.
Your model may be similar, but it's basically the same. Just be very careful not to break the plastic wedges or the data ribbon.
Jan 10, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
