Tv switches straight off when switched on. Red light flashes on front panel
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
My TV was working and then all of the sudden the screen went blank and now there is a flashing red light that appears. I tried to turn everything off and back on (the universal solution to everything) but...
Hello
There is something confusing the system control of your TV and it should me resetted. To reset it, just switch OFF your TV with its front panel power control switch, and after that, unplug the TV from the wall socket. Wait for about 5 minutes or so, and the plug it and switch It ON. If this does not work for the first time, give some more time to reset, say about an hour or so, and try. OK.
Jan 29, 2011 | Philips 37PFL5332D 37 in. LCD Television
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
My LE32S7 tv wont switch on. red light at
check for dry joints on power pcb, look for leaky caps on same
Aug 04, 2009 | Televison & Video
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Trying to turn o tv this morning and it switches straight back of, standby red light keeps flashing??
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV.
I will forward a link to a page where you can get more information and troubleshooting steps for this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Jun 08, 2009 | Sony Bravia KDL-42V4100 42 in. LCD TV
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
