-   My MW27FP1 did the same thing. It's about three years old and the lines started about four months ago, gradually moving downward. They now take up about six inches of the screen.-   laurieart
Sep 23, 2008
-   toshiba MW27F51 television white line vertically at the top of the screen, otherwise work fine
-   hitchhiker49
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
Toshiba MW27FP1 will not turn on. Checked 120VAC power going to the circuit board. Main fuse tested...
(More)
Toshiba MW27FP1 will not turn on. Checked 120VAC power going to the circuit board. Main fuse tested OK. Any help to terrypulliam@yahoo.com. Thanks, Terry
Toshiba MW27FP1 tv: Cannot select the MENU icon for setting the TV/CABLE options. It is the middle...
(More)
Toshiba MW27FP1 tv: Cannot select the MENU icon for setting the TV/CABLE options. It is the middle icon and the arrow keys pass over it without stopping to display the choices.
Started just occasionaly now is permanent. Just a white line through center of screen. The dvd...
(More)
Started just occasionaly now is permanent. Just a white line through center of screen. The dvd player will not read dvd properly, plays for a while and then goes into skipping and no play at all. help
My Toshiba Combo TV shows a horizontally line( the line is green ) when turned on I have no idea on...
(More)
My Toshiba Combo TV shows a horizontally line( the line is green ) when turned on I have no idea on whats wrong
