Question about Kenmore 4292x Front Load Washer
Kenmore Elite - F02 trouble
My Kenmore Elite HE3 will not drain and almost continuously switches to F02 error at the end, if not during a wash cycle.
Filter is clear. Drain hose in the machine and to the outflow drain are 'yucky' but clear.
Pump appears to work - spins - and impeller blades look intact.
What else could be the problem?
  • 172 Answers
Hi jbll,
The f02 code is always from a slow drain issue. This washer allows only 8 minutes for all the water to drain and if it is not gone in time you get the F02.
This is the proper check sequence for that problem.
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects. You can remove this easily and replace it if needed.
If the above does not correct the problem, replace the pump.
I hope this has helped, Lots of luck . Mike Anderson
mca0824@aol.com
Posted on May 02, 2008
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
We have a Kenmore Elite HE3, model # 110.45872 400. It goes through the cycle and almost at the end, it won't drain and flashes either F02 or F09. What is that and can we fix it? Thanks!
Hello, welcome to FixYa.
Based on your post I understand you have a draining error (looks like a F02 or F09 in the digital display...most likely F02 that is associated with the draining) with a Kenmore washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
Jun 29, 2011 | Washing Machines
I have a Kenmore Elite HE3 model 44832 200 washer. Will spin sometimes, but doesn't seem to get to full speed. Often won't spin at all and gets F02 error, but it does roll during wash/rinse cycles. ...
he F02 message is a long drain error and it may mean the pump is clogged or bad. You don't provide a lot of detail about if the water is draining out or not but the first thing to check for this error is the drain pump.
The image below shows how to access the pump and remove the filter. This may be your only problem. With the access panel removed you can also make sure the pump is running. Remember to unplug the washer before removing the access panel.
Check the pump for the F02 and make sure you're using HE detergent and there's not excessive suds.
Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 06, 2010 | Kenmore HE3T Washer
My kenmore elite HE3 front oading washer says 02F
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite HE3 front loader washer. I
"F02" is a Long Drain error. The error code is generated when the drain time exceeds 8 minutes. In most cases this means you need to clean out the trap on the drain pump. The following link explains the error and how you need to remedy the problem. There is a follow-on link included that explains how to access the drain pump and clean it: http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore If the error code reappears after you clean out the drain pump, you may need to replace the pump. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
A replacement pump (if needed) can be purchased at any of the following web sites:
searspartsdirect.com
repairclinic.com
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Sep 08, 2009 | Washing Machines
Kenmore HE3 f02 error
from what i read the presure switch is bad or the presure switch hose is clogged,one guy took the hose off and blew in it and no more f2-mike
Jul 21, 2009 | Kenmore Washing Machines
Our Kenmore Elite HE3 washer will not finish a cycle, flashing an error code of F02. Can you tell me what this is in reference to?
"F02" is a Long Drain error code. The following link explains:
In general, this usually means the drain pump or drain hoses are clogged and need to be cleaned. I have included instructions on how to do this as well.
It does not take much to damage these small pumps. Items begin caught in the pump impeller for extended periods of time can result in a pump that no longer runs, or one that no longer pumps at the correct volume. If cleaning does not solve your problem, the manufacturer recommends replacing the drain pump. Hopefully, a simple cleaning will solve this for you. Let me know if you have any questions, or require addtional assistance.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 4292x Front Load Washer Logo
333 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
