Question about Vacuums
Hi , I have replaced the electric cord on Electrolux Lux Royal vacuum , but the rewind that retracts the cord does not pull it in . The coil spring looks ok but it will not pull the cord back in , any suggestions please . Thanks Dave Ryder
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564353
Generic problem for all Vacuums
Hi, I have replaced
Posted by dryder on May 02, 2008
Hi, I have replaced the electric cord on Electrolux Lux Royal vacuum, but the rewind that retracts the cord does not pull it in. The coil spring looks ok but it will not pull the cord back in, any suggestions please.
Thanks Dave Ryder
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The question I have is it the Electrolux or the Royal cordwinder, if the cordwinder is sprung you may have to get a new one or a good used one, it’s been a while since I have done a cordwinder and I have seen it done, but I know when you remove the cordwinder you need to lock in the spring so that it does not loose it tension and re-coil ability. You may want to ask your local vac dealer to see if you need to repair or replace. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 02, 2008
Need to open the canister to get to the cord assembly of my Electrolux Lux 5000
Why do you need to get to the cord assembly?
If the cord will not retract, tilt the vacuum to about a 45 degree angle and gently tug and release cord. It will usually retract.
Due to problems ensuing from untrained persons attempting to reassemble the vacuum and having to take it to the shop anyway, I recommend not taking it apart.
If the above isn't the problem, please take it to the nearest Aerus Electrolux store for repair.
http://www.aerushome.com/storelocator/
Jan 22, 2011 | Electrolux Lux 5500 Canister Vacuum
How do I repair my Electrolux Lux 9000 cannister electrical cord retraction? It was pulled out as far as it would go and now it doesn't retract.
First, try standing vacuum on it's back end. Gently pull on cord and release. Try this a few times.
If this doesn't work, you'll need to take it to an authorized Aerus Electrolux store and let the service tech repair it. Although it's relatively easy to disassemble, reassembling correctly is trickier. I've had several machines come into the shop disassembled because the owner couldn't figure out how to put it together again.
Also, when taking the cord rewinder apart, there's a risk of breaking tabs that hold it together.
Dec 19, 2010 | Electrolux Lux 5500 Canister Vacuum
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
How do I open the canister of the Aerus Electrolux Lux Guardian? I need to replace the retractable cord mechanism. Aerus won't help me.
This will not be difficult to open, however, inside may scare you.
Remove your hepa filter cartridge (if you have one)
turn the machine over.
Undo the 6-8 screws there and pull the bottom off.
you should see everything there. If you are careful, just remove the old rewinder, and replace with the new one.
Good luck.
Mark
Nov 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
I can't recoil the electrical cord. What do I need to do?
Open the bag door, remove the bag (leave door open)and then with a hammer and a blunt instrument(wooden dowel) Strike the side rubber "bumper" rails towards the open door side of the machine from the back of the vacuum. You should get it started and then it should easily pull out from both sides. you can remove the bottom of the vacuum and remove the cord "guard" to allow the cord to go thru also. The back is held on by the union of these two halves by dowel pins(plastic nubs) Sometimes the "spring" mechanism gets jammed from over pulling. Just simply roll the smaller wheel to retract the cord manually. You could try spraying the rollers with a silicone or graphite type spray to allow free movement of the spring. Hopes this helps. WFServices
Jun 25, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
Broke cord reel on Lux Ren.
The only way is to replace the cord winder assembly.
Feb 20, 2010 | Electrolux Guardian Bagged Canister Vacuum
Retractable power cord
JUST LIFT OFF THE TOP HALF. CAREFULLY REACH IN FROM THE LEFT SIDE AND DISCONNECT THE CLEAR PLASTIC HOSE THAT IS ATTACHED TO THE "DIAL" ON TOP OF THE MACHINE. THEN LAY THE TOP HALF OF THE MACHINE TO THE RIGHT. DON'T DISCONNECT ANY WIRES. YOU'LL HAVE TO HAVE A NEW CORD WINDER (LOOK ON E-BAY). THE MOTOR AND CORD WINDER ARE ATTACHED TO EACH OTHER BY WIRES AND CAN BE LIFTED OUT OF THE CANISTER.EVERYTHING YOU DO JUST REMEMBER THAT ALL OF THESE PARTS ARE ATTACHED TO EACH OTHER BY WIRES. THE ONLY WIRES YOU'LL NEED TO DISCONNECT ARE THE ONES ATTACHED TO THE CORD WINDER ASSEMBLY. THEY JUST PULL OFF, NO TOOLS ARE NEEDED.
QUITE FRANKLY THIS IS A ROYAL PAIN AND YOU'LL PROBABLY WISH YOU TOOK IT TO A REPAIR (AERUS/ELECTROLUX) SHOP. IF YOU DECIDE TO DO IT YOUR SELF TAKE PICTURES OF EVERY STEP...'CAUSE YA GOTTA PUT IT ALL BACK TOGETHER.
GOOD LUCK!
Sep 08, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Automatic cord return
if it is anything like an electrolux there is a coiled spring inside that free wheels around a hub. pulling the cord too far out makes the spring slip on the free spinning hub. you may need to take apart the vac and rewind the spring.
Aug 28, 2007 | Panasonic MC-V9644 Bagged Canister Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
248 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
