Please help me
My pc has a problem and i think because of the motherboard. The problem is sometimes the motherboard startup normally but sometimes it does not start at all. can u solve it for me? Please
  • Dwayne Mendoza
    Dwayne Mendoza May 11, 2010
    Can you be a little more specific. What do you mean not starting up? Blank screen? Do you hear your hard drive turn on when you power up?
  • 101 Answers
Look into Power Supply (SMPS) RATINGS and the quality of the same.Use a power supply which has continuos or rated output of atleast 250 watts.
Posted on May 02, 2008
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
I have a K8V-MX motherboard. Recently, when i start the computer i will sometimes get no video, sometimes i will. When it doesn't work the monitor just goes into power save mode. Everytime everything...
that happend to me aswell, coz the asus motherboard are like that.
1st unplug all the cabels from the mother board like, harddrive ID and Cd-room ID, leave just the power supply on and try to start Your computer if it doesnt work take off the cabels of USB or anything else that is connected in the motherboard and try to switch it on, if that doesnt work.
get another graphic card and try with it maybe u have prob with ur graphic card, and if that doesnt work take of the motherboard from ur case and try to switch it on like that coz ASUS MOTHERBOARD are really silly sometimes.
hope that Helps.
Sep 20, 2011 | ASUS K8V-MX Motherboard
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
When I power my pc matherboard give lon sound and continue
Check the memory is pushed in fully and the fan is properly connected. If it proceeds normally after this it may be standard boot procedure - some old motherboards give a long beep during startup. (if none of the above works, you could try resetting the bios) Hope this helps! Max
Feb 10, 2011 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
No graphics on monitor whatsoever, screen completley blank
i think there is a problem with your system's hardware.. check whether your MOBO or your processor.. computers that doesn't startup and has no beep has defective or burned CPU or motherboard
Apr 18, 2009 | Foxconn 661FXME Motherboard
On startup fans only run a second then stop
I think this is fairly normal, most modern motherboards use thermistors to check the system temperature, (which windows then overrides) so on startup your fans will test for about a second and then turn off until the thermistor tells it the system is getting too hot ( I think this is called Acoustic management)
you should be able to bypass this in BIOS if you want, but as your system gets to windows those fans should kick in..
Apr 15, 2009 | MSI K8N Neo4-F Motherboard
I dont know the version of the motherboard driver of intel will suite my pc so help me with it..........
normally during startup it's shown (pay attention during the bios startup)
otherwise you can read it on the motherboard it self (if you find it easy to open your pc)
hope it helps
give feed back plz
Apr 03, 2009 | Intel Computers & Internet
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Is my motherboard defective?
i have accidently deleted video and sound drivers , and i dont have a cd to install that ,i have a biostar motherboard model p4m800-m7a i have tried to search the appropriate drivers but coudnt find them could please help me out
Oct 22, 2007 | Biostar P4M800-M7A Motherboard
Computers & Internet Logo
422 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
