I have wireless router and my laptop will no longer connect to the internet. The computer says wireless networks are available, but when I try to connect it asks me for my security key or passphrase. It's been so long that I can't remember what I used. Is there a solution?
    Novelist:
    Scholar:
  • 134 Answers
Maybe provide the brand of router.. Anyway, I have lost my details as well, several times over the last couple of years.. It's just a case of accessing the router (via web browser, using the correct IP address for your brand of router).. Then you can delete the existing network & add a complete new one. You get to use a new key & passphrase. If you need further help, please provide your router brand & model. Rgds, dave
Posted on May 02, 2008
How to install my router for wireless internet on my laptop.
1. Purchase a wireless router that fits your needs and price range.
2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
7. Click on "Properties."
8. Select the "Wireless Networks" tab.
9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
10. Click on "Configure" when you see your network's SSID in the "Available Networks."
11. Enter your network's SSID and WEP key.
12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Thanks.
Have great day.
Oct 01, 2010 | Computers & Internet
D-link DIR-625 wireless router is setup and wired to laptop
First of all make sure the Wireless switch in your Laptop is turned on.
Now Disconnect the cable from the Laptop to the Wireless router
Now go to your Wireless Network connection and search for the available network. Select the appropriate network and connect.
Thanks
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
I dont know to use wifi in LENOVO 3000 Y410
Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 1 Purchase a wireless router that fits your needs and price range.
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Can't Reconnect to Secure Wireless Network
    there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
    May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
    Help connect to internet
    Is there any other computer on line.
    If laptop is the only computer then connect the laptop to the router with the cable and check if that works.
    If you have other computer on line then you will need to check if your laptop is connected to the wireless network.
    You will need to check the wireless settings of the router.
    If your network is secured then make sure that you are typing the correct network key.
    also make sure that the DHCP server is enabled on the router.
    is there any computer connected to the router ?
    If yes then you can open the router set up page on that computer.
    Router set up page is the page where you can check all the wireless settings of the router.
    Click here for step by step instructions
    Apr 22, 2010 | D-Link 802.11g Wireless Router WBR-1310...
    Cannot connect to internet with konaki netbook
    How to Connect a Laptop to a Wireless Router Using a Windows Operating System
    Follow the router's manual to set up the router and its Internet connection , which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    Dec 12, 2009 | Computers & Internet
    Losing internet connection when enabling ICS on the wireless network connection
    Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
    Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
    Wireless router, laptop problems
    Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
    Jul 12, 2008 | Linksys Wireless-G WRT54G Router
    Laptop problems
    Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
    Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
    Computers & Internet Logo
    43 people viewed this question
    David Payne
    David Payne
