-   Casio Exilim Z 700 Digital camera. The lens projects when it is switched on, then nothing happens.
There's nothing on the screen and the off button doesn't work.
I thought the battery might have gone flat but there is no change after charging.
Any guidance would be greatly appreciated as I go on holiday in 10 days.
-   Guest
Apr 21, 2009
-   the shutter is stuck open and when you press the power buttom you here it but the it shuts right off-   Guest
Mar 16, 2009
-   i try turning on my camera , then the lens is stuck in there-   Guest
Dec 05, 2008
-   my shutter only opens half way.how can i open it to fix it?-   ridehrdjgb
Nov 28, 2008
-   My shutter stays open, the power light flashes green for a second and you hear the lens trying to retract but nothing happens. -   sliqriq83
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are out of warranty and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
when camera is turned on the display is only all white no image Model is VPC-T850 purchased early...
(More)
when camera is turned on the display is only all white no image Model is VPC-T850 purchased early this year
