FixYa.com
Tags:
Lexmark X73 All-In-One InkJet Printer
Does not print in color.
posted by tshirt on May 02, 2008
even with a new cartrige.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 02, 2008
FixYa! (100)
SkinWill
Rank:Wiz Wiz
Rating: 82%, 47 votes
Check the print setting in the driver config,
Check the print options in the document itself.
Check the print options in the printer menu.
Reseat the color cartridge in the carriage assembly.
Clean the connectors on the carriage assembly that connect to the ink cartridge with a slightly damp cloth or que-tip. if you use a que-tip make sure there is not any cotton left behind.
Try a factory reset on the printer, and reinstalling the drivers.
Also are you using a print server or any kind?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
lexmark5495 printer
I have tried everything I know... Answer This...
Lexmark x7350 will not scan,...
My printer suddenly stopped... Answer This...
printer won't print
I have installed two new ink... Answer This...
X73 found loose spring
My x73 wasn't feeding paper and... Answer This...
clicking printer
It seems that I'm having the... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
