Bad picture recently we had an earthquake in my town and sure enuff knocked my Magnavox MWC20D6 tele off the dresser falling about four feet it turns on and sound is fine but the picture is blurred and all the color shades are wrong if you have any suggestions id love to hear them thx Bryan
  • Anonymous Aug 13, 2008
    the tv fell during a move and everything works fine but the colors are all wrong. the middle section looks ok but the left and right are blue and green
  • Anonymous Jan 04, 2009
    All I have is a colorful line running horiziontal across the screen. I have good sound and the VHS player works great. What is the problem. Is the pic. tube blown and if so can I buy one and replace it myself.
    Thanks,
    John
You sprung the picture tube
Posted on Sep 12, 2008
I need help to get code for my magnavox tv/dvd model mwc13d6
U get the code, if any, from the manufacturer of the universal remote. Check the website for additional units that may not appear in the manual.
Jul 04, 2016 | Magnavox Nf102ud Tv Dvd Remote Mwc13d6...
Does a 99 lincoln have a knock sensor?
On both cars the knock sensor is located in the intake valley.
the computer receive signals if engine knocking and adjust the timing till stop.Before replace the sensors make sure the engine have no other misfire ,bad gas or vacuum leak.plug scan tool and read the code.Only circuit problem will be a true knock problem. Inspect all wire connectors before start taking a part.
Mar 28, 2014 | Lincoln Cars & Trucks
Drawer slides
Sauder has an 800 number on the instructions.
Nov 26, 2012 | Sauder 6 Drawer Dresser Lca225
My 50" magnavox 50ml8105d/17 making a knocking
It sounds like you have a bad color wheel. If you are handy with electronics, it is a pretty simple fix. If not, I would suggest you take your set to a qualified service center.
Apr 01, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
When i"m driving my volvo
Is the knocking a regular rhythm that is proportional to the speed of the car? Driveshaft center bearings generally drive you crazy with buzzing and grinding before they get to the point of knocking, but I suppose that is possible. Drive shaft and rear end bearings would not make noise as you start the car, however.
Is the knocking related to road surface or braking, and is it directly below your feet? If so, it is the control arm bushing. That part is bolted to the bottom of the car directly beneath your feet and it will knock when the rubber part fails and crumbles out. This is common on a car this old, but this part also would not knock as you start the car.
A knock when you start the car is more likely the exhaust pipe hitting the bottom of the car. This can happen if a bolt is missing from a hangar, or the pipe is bent, or an engine mount is broken. The engine mount on the passenger side is the easier one to see from the top, and is usually the one that breaks first, as I recall. I always suggest that engine mount replacement be left to professionals. That job is a good way to loose a finger.
Be sure and check the bolt in the bracket right at the rear of the engine. For some reason, this one works loose and the bolt falls out. You have to crawl under the car to see if that bolt has fallen out.
Another suspect is the transmission mount. Does the shifter move as you step on the gas and let off the gas?
Mar 24, 2011 | 1986 Volvo 740
Bad indoor pictures. When I take indoor pictures and it says to use the flash I do but then my pictures turn out dark/grey. Then I try it without the flash and they are brighter but then blury. I even...
The flash has a range of up to around 10 feet at the wide end of the zoom, down to 6.5 feet at the tele end. Maybe you are using it on to big a distance or at to low ISO? Try setting the ISO to 800 and see if it helps. images get a bit more grainy at 800 ISO but are also less prone to camera shake, if you use it without the flash. The camera goes as high as 1600 ISO, but images get very grainy at that setting.
Jul 01, 2010 | Canon PowerShot SX100 IS Digital Camera
TV stand stuck to dresser
Try spraying a little water near the feet and apply heat from a blow dryer. Not too much don't want to melt anything.
Nov 23, 2009 | Televison & Video
No sound on television
the speaker may not be connected to the board, check the wire. try replacing the speaker.
May 19, 2007 | Philips Magnavox 27MS343S 27" TV
Sides of screen greenish
sorry to tell you, most likly when the set fell, it caused a screen inside the set called a shadow mask to shift and the only way to fix would be to replace the picture tube. you could try unplugging the set overnight then replug back in but its unlikly that will help but always worth a try.
Oct 08, 2006 | Philips Magnavox 20MS3442 20" TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
