Question about Philips 26MF231D 26 in. LCD Television
Tv damage i have a tv magnavox model 26mf231d and i can see nothing the screen is only flashing every second and doesn`t show nothing. what i must to do??? thanks in advance for your help.
  • peiper May 25, 2008
    thank you for help me again.
    i have been checking my tv and i have some comments again.the rear panel (LCD) has 2 modules 6633L-0223F & 6633L-0224F (back light inverter you know i suppose). here el voltage is oscillate betweeen 18 vcd and 24vcd. when the screen is off the voltaje is 18 and when the sreen is on the voltaje is 24vcd every moment happens this. i have pictures and videoclips about this could you send you? what is your email..or your last comment is correct
    could you explain this??
    Scholar:
  • 72 Answers
It sounds like u have a damaged lcd panel. When your panel gets like this there is not much u can do to fix it. It will be cheaper to get another TV than to order a replacement panel. If your bought the service protection plan you can get it replace no problem but if you didn't. There is not much you can do for it.
Posted on May 10, 2008
Model 26mf231d. Why does it flicker a few times when turned on but doesn't show a picture?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 29, 2016 | Magnavox Televison & Video
I have a 26mf231 Magnavox 26 inch tv. The screen on the tv just flashes over and over. Never powers up. I took out the power board and all the capacitors look good. Thanks in advance
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | Philips 26MF231D 26 in. LCD Television
My magnavox 26mf231d/37 won't turn on
look it would be best to at least get a "Quote" from a reliable place for a fix, then you can at least make an informed decision.
Jan 31, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Picture black & white menu color #26mf231d/37
I have the same problem too. Need a fix. This tv isnt that old and is not used that much. does not seem to be the cables or cable box. the menu has color to it but the channel picture is in black and white, flickers a bit, and seems to be in a very large pixle form. it this able to be fixed? Please Help.
Nov 10, 2009 | Philips Magnavox 27MS343S 27" TV
I have a magnavox 26MF231D/37 lcd tv. It has good sound but no screen, just black. Turn it on and off aqnd it doesn't flash no anything. thanks
Either your inverter board or video board is bad. If you can see picture while the TV is on then its your inverter board. If not, video board.
Nov 05, 2009 | Philips 26MF231D 26 in. LCD Television
32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Jul 04, 2008 | Philips 26MF231D 26 in. LCD Television
LCD television (Magnavox 26MF231D/37) is turning on and off on its own, with picture going out in such a way that the images disappears then grey lines appear across screen and loud sounds come out of the...
I have the same problem.
and so do MANY others:
another fixit post tells you to remove the back and take off a metal part: http://www.fixya.com/support/t255942-power_cylcles_off
This is the older brother: A lot of the reviews describe your very problem.
http://shopping.yahoo.com/p:Magnavox%2037MF231D%20Television:1994315520:page=user-reviews
Magnavox should do something about this!
Apr 07, 2008 | Televison & Video
Green verticle line on Maganavox flat screen tv
Most likely it's due to the LCD panel assy failure. It may cost you as much as to buy a new tv. The LCD panel is very expensive in retail market.
Jan 24, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
TV Powers off after 30-45 mins
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 24, 2007 | Philips 26MF231D 26 in. LCD Television
Magnavox 20MS233S
Has it been moved latley? try to unplug it over night then try it. Sometimes they need to be reset. Some tvs go threw a test phase and need to do it a few times. If it has taken a fall it could be damaged or somthing may have come unplugged internaly. It may have over heated is it free from dust? electronics attract dust like a magnet. Is there any signs of somthing spilled on it? water damage?
Apr 04, 2006 | Philips Magnavox 20MS233S 20" TV
Philips 26MF231D 26 in. LCD Television Logo
175 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
