FixYa.com
Tags:
Whirlpool 24 in. ADG6340iX Built-in Dishwasher
Whirlpool Dishwasher DU850DWGX1 won't completely...
posted by MRKEWL1 on May 02, 2008
All drain cycles result in water still in the bottom including final rinse. I checked the drain hose and it doesn't seem to be clogged. With the drain hose disconnected from sink and in a bucket, water barely comes out. Any ideas? Thx
Comment by MRKEWL1, posted on May 02, 2008
Also during drain cycles water still comes out of spray arm assembly.
Only dishes are not getting clean and it just started doing this a few days ago, dirty water remains in the bottom. Before, the tub has been empty of water after the final rinse cycle.
I cleaned out the drain check valve and it appears to drain properly now, small amount of water just above the tub strainer.
Thx
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
elhomspam
Rank:Guru Guru
Rating: 86%, 16 votes
Commonly this is result of low water pressure or hose height/length
As long as the water is below the heating element and the dishes are getting clean its actually normal. Sometimes the pressure or hose length/height meets specs but will not always drain all water.
But as long as it is below the heating element this is normal
I am sure.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
Dishwashers
quiet parner 1 du1055xtpb3...
quiet parner 1 du1055xtpb3... Answer This...
Dishwashers
Model LD 1403 W!- 6
Model LD 1403 W!- 6 months old.... Answer This...
Dishwashers
Leaking from under the...
Leaking from under the... Answer This...
Whirlpool 24 in. ADG6340iX Built-in...
Whirlpool Dishwasher DU850DWGX1...
Only dishes are not getting... Answer This...
whirlpool ADG 6340
Dishwasher fills and empties... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
