Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
SAA7130 TV Tuner...
I can see the TV programs from my cable TV. However there is no sound. I connected the audio output from the SAA7130 card to the motherboard audio input. Windows XP still produces normal sound. However, I can not hear any sound from any TV program. What is the problem and what is the solution. Thank you.
  • avitwin May 05, 2008
    I bought philips saa7130 TV Tuner/FM year 2005
    and my softwar disk damaged
    please help me to find driver audio and video
    Avi
    avitwin@gmail.com
    Novelist:
    Scholar:
  • 148 Answers
DOuble click your speaker icon near the clock. click file then advanced, in the advanced menu select teh RECORDING radio box and click OK to return to your volume adjustments.
toggle the check boxes under each input and make sure they are turned up while you are trying to watch tv. when  you find the one that has the sound from your tuner go back to the advanced menu and make sure that input is checked under playback.
Posted on May 02, 2008
How to connect Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) to pc to get sound?
you need a cable 3,11 to 3,11 plug conector , buy it the price is like $3
concect to the audio port of the tv card behind and conect the other extremo to the pc sound card , and play it
May 31, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a frontech pci tv tuner card with philips chipset SAA7130 installed on pc gives images but no sound?
Hello
The package contains an audio cable, connect the cable audio out from card to audio in of computer and connect the speakers at the same place where it is,
or you can directly get audio from tv card by connecting speakers to audio out connectors.
Hope this helps, if so do rate the solution
good luck
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
ENTER saa7130 tv capture card not working properly
You need to make a cable with both ends with 3.5 mm jack socket. Plug one jack socket in audio out from tv tuner and the other in the line in from your sound card and will work.Good luck
Apr 01, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
No sound from the tv tuner card
1. Did the sound ever work?
HARDWARE:
2. If so, then the short cable that is connected from the TV card to your computer sound card came loose.
3. If it has never worked, then you need an audio cable to connect the TV Audio OUT to your Sound card audio IN.
SOFTWARE:
4. If it has worked and the cables are ok, then the "Audio IN" mute box is checked. Double-click the "speaker" icon on the lower-right of your desktop. UNcheck any of the audio mute boxes.
It should work now. If you need clarification, please reply.
Hope this helps!
Sep 03, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
No sound from my Sabrent TV Tuner / Video Capture
What he means, is that you should get a cable to connect your VHS player with the soundcard. Presumably your TV card doesn't have integral sound. Look at the connections. Your VHS player probably takes phono cable, while your soundcard probably takes mini-jack. So a cable that has a single stereo mini-jack in one end and two (red and white or occasionally black) phone connections in the other end. Those are easy to come by if you go to an electronics store.
Jun 25, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Intex tv tuner card SAA713x and computer sound on one point
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS 1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot) 2)plug ur spker to line out jack(green slot in computer) 3) double click on small spker icon (left side to ur screen near clock) 4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >ok And all done have fun
Jun 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
TV TUNER
Do you have a satellite TV tuner with an AV output on the back of the unit?
If you take the video output from the satellite tuner and insert it into the line input of your TV tuner card.  The audio output from the satellite TV tuner can go into one of two places.  The audio inputs of the TV tuner card or the mic input of your sound card.
Sep 13, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Turning my saa7130 into my default audio card
I went through the same issue when I bought this unit new. After going round and round, I learned that you MUST use the little dual plug audio wire to put on end into the video card OUT plug (green out line) and the other end into the Audio Card IN (blue in line). That will splice your TV Card into your audio card and sound will miracuosly appear (once you fine tune your audio outputs!). Hope that helps!
Jun 27, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM... Problem
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >okAnd all done have fun
Jun 26, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
206 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
