Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
We have a 1978 Coleman tent Trailer and we need to find instructions how to replace the cable that lifts up the roof to have the beds come out, Can you PLEASE help
  • jeniffer909 Feb 18, 2009
    just got this starter pop up and have the same problem, the cable is broken, how do we fix this?...please advise any info or helpful hints! thank you.
Take it apart! the cable is 1/8" gav. cable buy a crimping tool, take you time It is alot of work but I would not do a half job with something that could fall on my head I just replaced the cable in mine it alot of work but not alot of brain!
Posted on Apr 29, 2009
If the cable is broken on the bottom of the trailer jest cable splice cable if it is broke in side the suport i have 3 of them
Posted on Mar 09, 2009
Interior lights inop jayco pop up tent trailer
I have a 99 Jayco Eagle Tent Trailer and had this issue of no interior lights. I discovered that the kill switch was stuck in the off position. On my trailer, it was located on the inside of the roof about 1 ft. from the end of the roof where the electrical wires come down the black protective tubing. This is on the road side of the trailer.
Mar 06, 2013 | Sport & Outdoor - Others
Bent tent trailer rails for pop out beds, how do we fix
Try bending rails back into shape or make new (stronger) ones. I have shared your experience. Set up trailer in rain, jumped into bed, and supports fell out! Also set up tent in the dark in the rain after one quick lesson and no instructions.
Nov 18, 2011 | Sport & Outdoor - Others
Broken lift cable 1994 Coleman Tent Trailer. The cable that lifts it up when you crank it up
Hi well what you need to do is cut a piece of the cable off, and go to a place that stocks and sells nylon cordage, then simply obtain a length that will do the job, then once that's in hand, simply remove all the old cord, and replace with the new one, just reverse whatever you do when you remove the old stuff. It's basically just a bit of rope?
Oct 08, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
I have a disney princess tent that goes over a twin bed and i lost the instructions to putting it together and i need help.
  • 1
    Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
  • 2
    Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
  • 3
    Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
  • 4
    Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
  • Apr 22, 2011 | Toys
    I have a coleman Weathermaster tent I bought a couple of years ago the model number is 2000002250 the issue im having involves the plastic elbows that come with the tent that ties the upright tent poles to...
    I have the same model number tent and have some broken connectors as well. I could not find any replacement parts any where local or online. I called Coleman's customer service number at 800-835-3278. The tent has been discontined but they had a few of the connectors "in the office" and shipped me three. Give them a call; they were extremely helpful. Coleman customer service is top notch in my book!
    Mar 06, 2011 | Coleman Sport & Outdoor - Others
    Interior lights, appliances work fine when plugged
    Check for a faulty inline fuse or circuit breaker at harness attached at front of trailer. Follow positive wire back to trailer.
    Jul 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
    I have a '93 coleman, cedar tent trailer with a broken rear bed. The bed extends through the end of the track and comes off the rail. I'm looking for a diagram, parts list, and repair advice.
    I have the same issue. It looks as though the rivets broke off. I have yet to reattach the slide mechanism. Normally the slide mechanism is stopped by a peice of emtal about 1./2 the way down the slide. Either new rivets or some flush head screws might sole your issue.
    Oct 19, 2009 | Coleman Sport & Outdoor - Others
    Manual for 1982 Coleman Niagara Tent trailer
    One is available for download from http://www.popupportal.com/manuals/Coleman/Coleman_1982.pdf
    Jul 02, 2009 | Coleman Sport & Outdoor - Others
    Heating & Cooling Logo
    491 people viewed this question
    Top Coleman Heating & Cooling Experts
    Bill Long
    Paul Carew
    Dan Webster
    Dan Webster
    Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
