Question about Gateway FPD2275W LCD Monitor
Samtron 45bn problem
Hi..got a problem with the samtron 45bn monitor. Initially, the screen turned yellow, then afterwards the screen went blank ie. black altogether... the monitor switches on alongwith the PC but remains blank..guess its a cable problem..plz help..
  • ritzi31
    ritzi31 May 22, 2008
    thanks for the reply..checked the cable and found it to be alright..guess the internal circuitry has locked or something as the light in the front panel is always on..how do i go about repairing now..
    New Friend:
Hi sirs, i am also having problem with samtron 45Bn monitor
the problem is given below pls give me you help
I have Samtron 45Bn Monitor with CPU.
I connected these two devices with 0.5 KV UPS.
I switch on the system it turns on windows operating system turned up.
During the operation inside the monitor their is a sound like"Chirk Chirk Chirk"
Due to fear I suddenly switch of the UPS.
then later i switch on the UPS and switch on the monitor button but the power LED light is not light up.
and monitor not working.
the cpu is working but monitor is not working
if i connects with the power and switch on the monitor the led light not light up and monitor not on
so please kindly give the solution
regards
Posted on Mar 12, 2013
HI I AM SAMTRON 45BN COUSTUMER
MY PROBLAM IS MY MONITOR HAVE ON AND FEW MINUTE LED GLOW AND AUTOMATIC OFF
Posted on Dec 15, 2008
Yes cable problem
Posted on May 02, 2008
Problem in Samtron 45Bn Monitor
Try connecting the monitor to the mains instead of the UPS.
If it works OK then the problem maybe the UPS and that it is very close to the max output of the UPS.
If not then the monitor is faulty.
Mar 12, 2013 | Computers & Internet
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Desktop screen is stretched abnormally
please trie and double check the resolution on the screen that its correct.
Also check so you dont use too much Hrz on the monitor/settings.
Jul 14, 2008 | SAMTRON 55V 15" CRT Monitor
Problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
May 25, 2008 | Computers & Internet
Samsung 45bn
hi... there's a resolution problm with samtron45Bn with win xp.
Pl.help to fix this pblm.
May 22, 2008 | Computers & Internet
Default monitor
Sounds like you need to install your video card drivers, to get the resolution you need.
Jan 06, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
239 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
