Question about Ezonics EZCam Webcam
Can't find server.Can't get on internet
I have a Dell PC and changed over to Time Warner Cable and the cable tech said the computer can't find drives,ether net.Can't find server.It always worked fine before the switch and even connected to the internet once after the switch.He said to reinstall original software,which we no longer have.we don't want to lose anything stored in the computer.We have another computer plugged into the router and it still works fine.
  • 818 Answers
Go here for your driver:
http://www.shopezonics.com/Articles.asp?ID=108
Sergio
Posted on May 02, 2008
I cannot get online with my neighbor's internet service. They have an open access signal with Time Warner cable and my message is that I need to renew my ip address to make a connection. I have
To renew the IP address under Windows XP, you issue the following two commands in sequence under command line (aka cmd):
ipconfig /release
ipconfig /renew
Feb 19, 2012 | Dell Computers & Internet
How do i set up internet on a dell computer we just got? have a modem and time warner internet...HELP!
Plug in the cable from the wall into the modem.You need an ETHERNET wire to connect from the modem to the back of the computer.It is yellow,universal,and you should have received one from Time Warner.It will fit in only 1 spot on the modem and only 1 spot on the computer.I also have a Dell.Good luck if you EVER have to call for technical support.One time I called,they asked me to say and spell my first namke.G-r-e-g-o-r-y.She replied,ok let me read that back to verify it.Now that's T as in Tom...They have an accent,it is eastern,but much farther than New England to Florida.Good luck! Greg
Oct 27, 2010 | Computers & Internet
Just had a new router put in by Time Warner Cable and they synced all our computers to a MAC address. We have 4 computers on this (2 desktops) and 2 laptops. Only one is having a problem, the Dell...
I would need a few more details to really get to the heart of this but the first thing I would do is connect this Dell to the router with an actual cable, if only temporarily. See if there are still issues when directly connected. Depending on answer to that you would know if the wireless is some how responsible or if there is some other cause. If there are no issues with a direct cable I would say it is the wireless card or signal. You could a try different wireless hardware on the dell or switch channels on the wifi router to see if that helps. I can't think of a reason why four computers on the same router would respond differently to a specific site.
Jun 02, 2010 | SMC EZ Connect Modem
Connection issue
Hi! I believe your having some issue with your router and I will be more than glad to assist you in this concern..Time warner cable is your isp and if the computer is connected directly to the modem, you have a perfect internet connection but if you are going to connect the cable from your modem to the router and you connect your computer to port 1 to 4 of your router it will not give u an internet connection. This is what we are going to do.
1. connect your computer that can get an internet connecttion thru time warner cable to the router on port1.
2. pull up a browser and type in the default gateway of the router, to check the default gateway of the router, right click the network icon on the lower right of the task bar and click status and it will show the ip address, subnet and default gateway, ex the default gateway is 192.168.1.1, u are going to type in the default gateway ip address to the url of the browser.
3. It will ask u for the username and password, by default the username is admin and the password is 1234 or just leave it blank.
4. It will pop up the setup page of the router and you have to look for the setting for doing a mac clone, you need to clone the mac address of your pc that can connect to the internet thru time warner cable modem.
5. once its done, save the settings and on the internet connection settings, manualy configured it to auto-dhcp. save the settings.
6. once its done..unplg the power of the computer, router and modem.
7. cable connection should be, cable from the modem goes to the WAN port of the router and connect cable on port 1 of the router to your computer on the lan port.
8. Plug in 1st the power of the cable modem, once all lights are lit then plug in the power of the router, once all lights are solid on the router, like the power, WAN, u will notice that there is no light on the port1, computer is still off, once the computer is on port1 will lit, then power on the computer..once computer is completely boot up, pull up a browser and it should gives u an internet connection.
9. Once you have an internet connection, u can access again the setup page of the router to setup the wireless connection settings.
10. If you are going to connect another to the existing router that is conneted to the time warner cable. that is possible, but before u connect the 2nd router to the 1st router..
a. connect the 2nd router to a computer to set it up..you have to access the setup page of the 2nd router.
b. once you access the setup page, there is a menu for the lan settings that is for the router side. u need to change the 3 octet of the ip address of the 2nd router. ex your 1st router ip address is 192.168.1.1 and the 2nd router ip address is 192.168.1.1 to change the 3 octet of the 2nd route, the 2nd router ip address should be 192.168.2.1. then save the settings..
c. the router will reboot and need to access the setup page of the router by using the 192.168.2.1 and u can set the wireless connection settings.. once its done..
d. cable connection should be---cable from the time warner cable goes to the WAN port of the 1st router, connect a cable to port 4 of the 1st router going to the WAN port of the 2nd router.. this process is called cascading two routers on a network.. this should work.. good luck
Aug 16, 2009 | ViewSonic (DHWMG120) Router
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
Problems connecting to the internet
unplug from power all things then plug back in,in this orderthe modem,then in 2 minutes,the computer,it should reset
Apr 20, 2017 | Dell PowerEdge 1800 Server
Ping is high at closest server. But low at servers much further
hello there i have built many wifi networks and install networks for server hosts.
I would try setting your port forward to the correct port that xbox live runs on.
also uncheck Qos (quality of service) this will throttle bandwidth, you want this off.
Jan 26, 2009 | Microsoft Xbox 360 Console
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Dynex wireless modem
Your expert Geokohler helped me fixed the problem and soved it for me. I sent an evaluation giving him a "fixit" rating.
Jul 21, 2008 | Dynex DX-E401 Router
Ezonics EZCam Webcam Logo
121 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
Larry Maranto
Mark Gough
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
