Question about Kitchen Ranges
Maytag oven: How to clean
I move the handle to the right to lock the oven door and then press the Clean button. What else do I need to do?
    Scholar:
  • 58 Answers
Before you self clean you always want to take a rag with warm water and remove all chunks of food.
Next clean around the frame of the door gasket with the rag(these cant get clean in self clean) do not clean gasket IMPORTANT
Remove all racks and pans
Most older door handle locks require a few buttons, get your model number(which is located either on the frame your bottom drawer shuts on if a single oven, if double is on door frame if built into cabinet walls, if on floor its on back of control panel, a piece of metal thats like a mailbox flag, you turn it to read model from front) and go to www.maytag.com click support then manuals enter your whole model number EXCEPT the last letter. (example if your model is MER6775AWW enter MER6775AW<--only one W) This should bring up use and care guide, which will give step by step instructions, if you follow them and it wont clean, your latch most likely needs replacement
Posted on May 02, 2008
How do I start the self clean cycle on my oven.
Is there a door lock handle? Lock it! All self-clean ovens must be locked before the unit will clean, if it is an automatic lock, the door lock motor might be bad.
Apr 24, 2016 | Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
How do I lock door for self cleaning
Some ovens have a latch handle between the top of the door and the actual range top that you have to push sideways to lock. May also be a lock button you have to push in while moving the latch handle.
If you don't see the latch handle, The lock system may be the hidden type that should lock automatically when set to clean. Once the oven is set properly for clean, a motor will latch the door by itself. After the oven gets close to clean temperature, the latch gets locked out and the door will not open until the clean cycle is complete and oven cools down to normal room temperature again. This is a safety feature so you can't open the door while the oven is at clean temp (about 850 degrees). Hope this explains enough. If door never auto latches, could be a problem with the latch/lock system and motor.
Mar 29, 2015 | Ovens
How to use self clean for oven
Turn off the oven light and remove all pans and racks from the oven. Clean the oven and door frames with a non-abrasive cleaner. Do not clean the door gasket. Remove any excess grease or debris from the oven bottom.
Close the door and move the lock lever to the right. The "Lock" indicator will light. Press the "Clean" pad, then press the up or down arrows on the "Set" pad to adjust the cleaning time: two hours for light soil, three hours for medium soil and four hours for heavy soil.
Cancel self-cleaning after it has started by pressing "Cancel."
Wait one hour after the cleaning cycle has ended for the "Lock" indicator to go out. Unlock the door.
Clean the oven racks with soapy water and a scouring pad and put them back in the oven.
Sep 25, 2010 | Maytag MGR5752BD Gas Range
I accidently pressed self clean instead of boil on my oven
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
Frigidare Self Clean Oven
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
3. PRESS THE "COOK TIME" BUTTON
4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
5. PRESS "START" BUTTON
6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
How do you clean self-cleaning Maytag Gemini?
If the unit is a self-cleaner, you should remove everything from the oven (including the racks as the self-clean mode will remove necessary lubrication from the racks if left inside). If the range has a slide lock on top of the oven door, move it from left to right to lock the door, then press the self-clean button. If it does not have a slide lock, it should have a magnetic lock which will engage when the self-clean function is activated. The oven will reach approx. 800 degrees for about 3 hours. When it cools, you should see a white powdery substance in the oven. Wipe this up and you are done.
Mar 22, 2008 | Kitchen Ranges
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Dec 18, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Kitchen Ranges Logo
200 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
