Question about Shure SM81LC Professional Microphone
Oops. took apart my sm81 condenser microphone
this is the best illustration i can find showing a typical diaphragm/backplate - apparently it's the capacitor or condenser assembly. there's very delicate spacer/washer(?) between the diaphragm and the backplate, shown in the picture but not labelled. i noticed that one side is shiny. does anyone know what it does (insulation?) and whether it matters which way round it goes.
Steady yellow after dropped
Does it show up in Device Manager?
Aug 14, 2013 | Samson Meteor Mic - USB Microphone
My Rode Nt1A also stopped working. I think its because i took the silica gel bag from the case. Should i always keep the mic inside the case after the usage. and i dont use a pop up filter
Removing the silicone bag and not using a pop shield can lead to condensation on the diaphragm. Place it in a bag of rice for a day to dry out any condensation on the capsule.
It may not be due to condensation though. Make sure your phantom power source is working. If possible attach another mic to the same source to see if it works. Check the contacts on the mic and also check the wire for any erosion or debris. If none of these work, fixing the mic may be beyond DIY repair.
Aug 31, 2011 | Rode NT1A Professional Microphone
I have a 6 year old rode nt2000 large diaphragm microphone which is making fluttering noises constantly. I'm fairly certain it's not any of the potentiometers being that the noise is very consistent...
This mic likely has a built in preamp. BEFORE you open the mic, verify that your pahntom power from your preamp is clean.
If you are unfamiliar with phantom power for mics, google it to find a treatise.
Noisy or failing phantom power could be your problem. Also the preamp in the mic could have a problem rather than the diaphram. Dust would NOT normally cause what you are describing.
Sep 28, 2009 | Rode NT-2000 Professional Microphone
Autimaticaly a clip sound occurs at regular interval
This is typical of component failure, and possibly capsule issues, as well. The mic requires professional service. Condenser Microphone Mod Service
Aug 19, 2009 | Rode NT2 Professional Microphone
Rode NT1-A Distortion on "S" sounds and plosives
This is typical component failure. The mic will require professional service. Condenser Microphone Mod Service
Nov 01, 2008 | Rode NT1A Professional Microphone
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
Aug 12, 2008 | Audio Players & Recorders
Shure SM81LC Professional Microphone Logo
103 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
