Hi, You will need another person to do this (adalt) Have him sit in the driver side holding the brake.
Shift the car in gear as you check the transmission dip stick. (Automatic) If you have a manual transmission you will have to crawl under the car and undo level check bolt.
Check shift linkage when you are under the car.
If transmission will not shift syncro gear maybe out of sync. I would suggest that you may not be able do the repair on automatic transmission because it is very difficult to do.
Simple answer: No. Polos and Golfs use different mechanical components.
More complicated answer: If there is that much damage then the bodyshell mountings are also quite likely to be distorted which will make any repair attempt futile. Ideally you must get the damaged parts stripped off and then get the mounting points accurately measured. This can only be done using specialised measuring equipment. The alternative is to invest in the parts needed for your repair and to fit them with an immediate alignment check at the nearest suitably equipped garage. If the alignment of the body is off then the car is effectively a write off as repairs will exceed the car value.
Got to have the special tools (or equivalent) to hold down the pulley bolts if it's a VR6. A 2.0l you'll need a timing belt tensioner tool besides the pulley counter holder. And better buy a Bentley official VW repair manual. Buying a Chillton, Hayes or Clymers will make your repair more difficult to understand.
Changing the automatic transmission fluid on this vehicle takes special fluid and equipment which includes a scan tool that can read transmission fluid temperature. I would recommend going to a VW dealer or service center that works on VW’s
A you first or second owner?
depends how you drive, economical or sports, provided doing regular service, it is difficult to say these engines can go for 100 miles and can withstand even more so
under the mirror there should be a 1 1/2 slot door under mirror that looks like a flat lid this will be flush with mirror moulding where it looks like a quarter can turn it
this is the light access panel the detachment screw is threw this panel to take off mirror then you can access the bulb
