Hp tc 1100 got switchedoff all of sudden either power is working or system got shutdown and it is not coming up
  • choudary1 May 02, 2008
    hp tc 1100 got switchedoff all of sudden either power is working or system got shutdown and it is not coming up
    Novelist:
    Scholar:
  • 148 Answers
Unplug the power to the system completely.
Locate the mains voltage selector switch and toggle it from 110 to 220 and back a fiew times. BE SURE ITS SET BACK!
This has been known to reset a power supply that is in SHOCK.
If this does not work or you cannot find the red selector switch. then leave it unplugged for a while and check that there is nothing shorting the power supply.
Also let me know if it is able to DO ANYTHING like lights or if it looks to be trying to start and where it dies.
Posted on May 02, 2008
Sudden shutdown
If the battery is full and still shuts down suddenly then it could be a heatsinking problem on your Notebook. Also try unchecking the option "Automatically Restart" from StartUp & Recovery section in System Properties.
May 03, 2010 | HP Pavilion dv6000z Notebook
Resetting an air conditioning system in a scion tc 05
Hello.... First the bad news... Air Conditioning systems do not have a reset. Now the good news... The system could have shutdown due to low fluid... There is a pressure sensing switch in the line that respond to the "Low Fluid" condition.The reason it does that is so that the compressor does not get damaged and cause all sorts of other problems...
The fix... If it has shutdown due to low fluid the system needs to be serviced and it will start working as good as new... Take it to a repair shop with the proper equipment..
Hope this helps.....
Mar 26, 2010 | 2007 Scion tC Coupe
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
It shutdown suddenly while working
If Ur Laptop Shutdown While Working. Then First Check Out Your Bettery Life. If It is ok Then Make Sure Your Laptop Didn't Heat more. If Still You Face Problem Then Contact Hp Care No : 1800 112267.
Jul 29, 2009 | HP Pavilion TX2000Z Notebook
Hp 530 booting problem
Check to make sure you have it plugged in and not working off the internal battery. Sounds like a low battery power shutdown.
Jul 11, 2009 | HP 530 Notebook
Will not power up
try to start it with the battery removed but power plugged in, sometimes when the battery or charging system fails the system will not power up at all with battery attached
Feb 03, 2009 | HP Computers & Internet
Compaq dead after power company shutdown period
Sounds like a blown fuse in the psu, replace the unit and you should be good to go.
Nov 30, 2008 | HP ATX-250-12Z, ATX-250-12Z Rev. H1, HP...
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
