Can not change my tv's display mode above 800x600
    Problem Solver:
  • 23 Answers
Hi
What brand and model is the TV? Is this new or has it always been like this?
-Damian
Posted on May 02, 2008
It says something about DISPLAY MODE AND IT CANT START THAT ALWAYS POp OUT
"Could not find display mode"
change the resolution manually by changing the "Battle Realms.ini" fiel in the main Battle Realms folder, change it to 800x600
Sep 17, 2011 | Ubi Soft Entertainment Battle Realms:...
Cannot see all of IE at one time. Have to use
Go into Start >Control Panel> Display or Personalization (XP-Vista).
Find Display Settings and then look for resolution. Change the resolution up a notch (higher numbers) and look at the screen. If you like it, save the changes, if not, change until you like what you see on the screen.
Nov 21, 2009 | Dell E173FP 17" LCD Monitor
Picture to large on Windscreen TV to see Menu from PC
First try changing the screen mode on ur TV, FULL/ZOOM/WIDE. If not then try changing the desk resolution on ur PC to the same resolution ur TV is. to be save just change it to 800X600. If that wrks then look in ur manual or right the bos it cam in, shld say what the TV max resolution is.
Nov 21, 2009 | Dell Dimension 4550 PC Desktop
Out of Frequency error
1. Start Windows in safe mode by pressing F8 and Change the display properties to 800 x 600 16bit
2. Restart in normal mode
3. If the 800x600 screen resolution doesn't work try going into safe mode and trying a lower resolution
Jul 17, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
GeForce 6200 PCI when drivers are loaded, screen goes blank
the problem is with display resolution setting which ur monitor doesnt support
press f8 on startup and choose enable vga mode
then widows will boot up in 640x480 mode
then change the resolution to 800x600 or whatever u want
thanks
Apr 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
GeForce 7200 GS 256MB won't work with tv
"the tv works and I can see my extended desktop, but ONLY in 800x600!!! Also when I tried to watch a movie on the tv, it only showed a black block"
1. Tv's only support max of 800x600 (technically less)
2. Windows has a built in ANTI theft BS protection that makes viewing video through an alternate output show up black boxed.
Mar 16, 2009 | Nvidia GeForce 7200 Graphic Card
Monitor hibernation.
Any key! This may help if its a display setting problem:
Fn & F5 simultaneously, cycles the display output through the 5 modes. (hold the Fn key down, and press the F5 key, press it again, give it time to change before you press it each time)
the 5 modes are:
1.built in display only.
2.built in display AND external monitor.
3.External monitor only
4.built in display and TV
5. TV only
*note: Internal display resolution must match external display resolution, and that resolution must be
at least 800X600, or higher
Apr 02, 2008 | Toshiba Satellite A135 Notebook
I'm trying to connect my toshiba satellite m115 to my insignia 19" lcd hdtv but its saying on the tv " mode not support " how do i fix that so i can watch my laptop on my tv?
Your toshiba m115, like my m105, is probably set at settings 1280X800. Once the LCD is hooked up to your laptop
  1. Right mouse click on empty spot on desktop
  2. left click on properties
  3. left click on settings tab
  4. left click on advanced
  5. left click on INTEL MEDIA GRAPHICS tab at top
  6. left click on graphics properties
  7. display settings
  8. change to 1024X768 or 800X600 (whatever lcd tv supports)
  9. click apply
  10. click on display devices
  11. make selection
  12. apply
Apr 02, 2008 | Computers & Internet
Trying to connect laptop to plasma tv model number 42PF9945. keeps displaying picture format not supported. using vga to vga on tv.
To my knowledge your Philips 42PF9945 is capable of a maximum of 852 x 480screen resolution at 50Hz. It is TV standard but pretty low for PC work, that being the case, perhaps what is required is for you to lower the Screen Resolution as well as the Screen refresh Rate of the laptop. They may be found in the display properties (Control Panel) or right click on any clear area of your desktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Televison & Video
Tiger Woods odd 3DFX mode Voodoo3 problem....
well download the latest driver for the GPU of the card.
and Also it will let you select higher resolution but may be your card is not DX 9 supported.
Jan 07, 2008 | Computers & Internet
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
