Question about OKI C5150n Led Printer
Oki c5150 fuser jamming
On and off when a sheet is maybe 1 inch out of the fuser it starts to jam up in the fuser (pull the paper out and it looks like an accordian). I bought a new fuser...and it is doing the same thing...I tried flipping the paper and filling the paper try up and no help.
  • ruger22com May 06, 2008
    I found my solution talking with our canon color copier repair guy at work. he explained that it is because 1) it is summer, thus my gas heat is no longer drying out the house humidity here in alabama, 2) I was using 20 and 24 pound paper which was absorbing the humidity in the air, then when the paper entered the super hot fuser unit, the moisture would turn to steam, and curl the paper so it hits the fuser extaction claws and jams.
    So I switched to a 28 pound hammermill paper that is designed for color copiers (has a green apple on the package) and is supposed to be "99.99% jam free" and after a few hundred copies, the jam problem has disapeered. I still get jamming on USPS green custom forms, but he suggested I keep them in a tupperware bowl sealed with a couple dessicant packs.....so I will give that a try. (hope this helps some other folks...and keeps you from buying a second fuser like I did).
  • 1,219 Answers
Ii may be that you have poor sensor flaper response, somewheare between paper pick up section and fuse unit. Check the paper registration sensor.On sensor flaper you have a spring wich can be dirty of toner or grease so she slows down the flaper.
2) did you check the pick up clutch?He is maybe worned out so he does not react in specific moment, and couses the delay jams
3) did you clean all the pick-up,feed and separation rollers.
Good luck
Posted on Feb 20, 2010
    Scholar:
  • 136 Answers
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
Posted on Aug 04, 2009
  • copiersplusw
    copiersplusw Aug 04, 2009
    Opps I saw you bought a New Fuser, their a guide the guides the paper to exit the rear, I would lower the rear tray to see if it jams if it doesn't the guide feed rollers is where it is jamming
Samsung SCX 4623F " Paper Jam Inside"
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 05, 2016 | Office Equipment & Supplies
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
Replaced the belt and fuser on a oki c5200, now paper gets jammed and accordians in fuser
This will happen if the belt isn't properly settled, so that the sheet of paper enters at a slight angle and jams. The roller loader will then fold it into an accordion shape.
While I don't understand how the printer let you print (the sensor should have raised an alarm), you could try extracting the belt unit and re-settling it. Verify the blue retainers have been fully rotated (one eighth turn clockwise) and the handle is completely down.
Nov 06, 2009 | OKI C5200n Laser Printer
Oki b6200 paper jam
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Feb 26, 2009 | OKI B6200 Laser Printer
Paper jam near fuser - OKI C5100n
okay, I have this problem I think. It is jamming on the OUTPUT side of the fuser, and I have replaced the fuser with a new one.
I learned tonight, through trying various things, that it will not jam with the printer lid open. (you can make it "print" with the lid open if you push the lid switch in so that the printer thinks it is closed. That made me wonder if it had anything to do with the led strips (black bars attached to the lid) so just for fun I unplugged the C led strip so that it wouldn't produce any light onto the drum. With the lid closed and the C disconnected, the printer will not jam. (but you get no blue on the page of course!) when I re-connect the C led strip, it jams on the output side of the fuser every time. It is very consistent.
I don't understand how putting blue toner on a paper can make it curl so much that it jams up in the fuser, but it does.
I'm sure there is something else gong on here that I don't fully understand- hopefully someone who knows more than I do can use this info to help us all out a little.
I'm going to go and fiddle with the drums now. I don't have an extra one right now, but I'll see if I can narrow it down further.
Sep 11, 2008 | OKI C5100n Laser Printer
OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Apr 07, 2008 | OKI C3200n Led Printer
Repeated paper jam in fuser
Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
Their may still be some card in fuser causing jams.
Please rate as FIxya or post back,
Cheers
S. :-)
Jan 01, 2008 | OKI C5200n Laser Printer
Paper jam 580
You know what I would try, look in the fuser unit and see if any paper ripped off and got stuck in there. Wait until it's cooled down, but usually if you have to pull paper of of there, little pieces can get caught in there. Also, you may have a full sheet in there, I've had people leave and entire sheet in the fuser all scrunched up and the machine print fine for another 100 prints and then have an error and the paper coming out looking like it almost caught fire.
That's where I would look first if there isn't anything in the print path under the toners, etc.
Oct 27, 2007 | OKI C5100n Laser Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI C5150n Led Printer Logo
450 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
