Hitachi Ultravision Model# 46ux17k
Tv was gave to me. When you first turn it on it takes about 10 minutes to warm up and get focus. Then when it comes on the color is weak and fades to black and white at times, and tried to adjust color from menu but no matter what I do it stays the same.
  • 2 more comments
  • waltham341 May 07, 2008
    Witch tube needs replaced? I found a dail on bottom tubes, and adjusted them and it helped a little. Also when I try and line up the color + the vitical line is wider fuze and squilly.
  • waltham341 May 09, 2008
    I have a Hitachi #46ux17k given to me. No matter what I do I cant get the color bright, I tried adjusting the knob at bottom of tubes and it helped very little. Also when I try and line up colors + line the verticle line is wider and fuzzy and some times its squiggley. And also the color goes black and white and back to color. I would like to fix this TV myself so any suggestions will help.
    ThankYou
    And also it takes about ten minutes to warm up
    I bought a service manual, were do I find the IC's your talking about?
  • 3,037 Answers
This type of problem is mainly due to problems in the IC and hence the tv loses its focus and color patterns. You will need to check your tv IC and most likely get it replaced which shouldn't be too hard if you know how to solder.
Let me know what you think when you check this, if you need any help let me know, also be aware of the capacitors which can shock you with an enormous charge.
Depending on the age of the tv, other parts may be contributing to the problem.
Posted on May 09, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    repair shops will not usually give a free estimate, it will be standard to charge at least $50 just to look at it.
  • Benjamin Patri
    Here is a link of what one would look like
    http://www.electronic-repair-kits.com/Re...
    They will be on the main board and should be labeled STK-150 or some other number, they are the first thing I would replace and shouldn't cost too much, they can be bought at an electronics store like Radio Shack.
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Sergeant:
    Champion:
  • 427 Answers
If you can, take it to a shop where they will give a free estimate. Then ask them what exactly needs to be replaced. If you have trouble finding one, call the troubleshooting phone number. (You can probably find it online). Then I would suggest looking on ebay to find the part for a cheap price.
    Guru:
  • 147 Answers
Your TV needs to get repaired. Take it to the nearest repair shop and get the lamp replaced. It can cost upwards of 150 dollars though.
Please let me know if this helps. Take care!
-Chimpster
Posted on May 02, 2008
  • Alexander Kogl May 02, 2008
    Has this helped? Please don't forget to rate it! :-)
Hitachi tranformer model 46ux17k
Not going to find that part which has been unavailable for over 10 years.
The transformer rarely fails so what makes you think it is bad?
What is set doing or not?
May 19, 2012 | Hitachi Televison & Video
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
What type of lamp needed
My lamp model is lp700 where can I order that part
May 07, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi Ultravision Digital TV Model 57SWX20B
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 08, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision digital widescreen
my tv has a magenta pink and green stripe accross the top of screen...is this a bulb problem
Nov 01, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
