Problem for Refrigerators
Generic problem for all Refrigerators
Ice Maker Won't Drop Ice
I have a Whirlpool side by side refrigerator with a new ice maker. The ice maker works fine but will not drop the ice. If I cycle the arm off/on (up/down) then it dumps the ice a few minutes later. Otherwise, the ice just sits in the tray. The ice maker is Whirlpool #4317943. Any suggestions on why it won't drop the ice or what to test?
Comments:
May 17, 2008
- Installed a replacement unit. Now this unit won't fill with water. There are no blockages in the feed tube. Any thoughts? Thanks
Same Problem
Jun 01, 2008
-   i have the same problem only in reverse. i had a cube stuck and the icemake stayed running. after removing the cube it no longer would fill with water. the module was burned out. i replaced the icemake, it filled, froze, dropped the cubes, filled, froze, and will not drop ay more cubes. i removed it 5 times and thawed and it does the same thing eveytime. it only drops the 1st set of cubes. the lights stays solid not blocked but goes out when the freeze light goes off.-
sstauss
Best Solution
posted on May 02, 2008
Rank: Guru
Expert
Rating: 88%, 906 votes
you have a problem in the module of the ice maker if it is new take it back for a new one
Popular Solutions for Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with...
1 Solution
GE (PSS26MSRSS) Side by Side Refrigerator
1 Solution
Hotpoint HSS25GFP Side by Side Refrigerator
2 Solutions
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with...
1 Solution
Questions and Unsolved Problems for Refrigerators
refrigerator about 20 cub top frezer
Posted. Thank You!
no water coming out of ice/water dispenser in GE refrigerator that is 5 years old
Posted. Thank You!
my 3 way fridge will only work on gas
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
I have a Samsung SRS615DP that is constantly beeping. The LCD panel indicates that the door is ipen...
(More)
(More)
I have a Samsung SRS615DP that is constantly beeping. The LCD panel indicates that the door is ipen but it is not. All seals are good. Have turned the frig off for over 48 hours but the problem persists. Anyone know the fix? Thanks.
Posted. Thank You!
The fridge section of my Miele fridge/freezer keeps freezing all my food! I put it on 'holiday...
(More)
(More)
The fridge section of my Miele fridge/freezer keeps freezing all my food! I put it on 'holiday mode' to defrost and within 24 hours of turning on again, it has frozen up.I don't hear the motor switching off at any time.
Posted. Thank You!
