Benq scanner while starting makes big noise not in working condition.Can you suggest a service center in chennai,india
I want benq scanner motor for the modle of 4300,suggest me were i can buy it pls send the address.my mail: chinna_diamond2005@yahoo.co.in
Posted on Nov 02, 2008
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
Brother mfc-j6510dw will not scan
This may help others with scanning issues:
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
My 575 fax won't send; it keeps printing "poor line condition". Is there something I can do? I am just trying to send a fax like I always do. It makes the noise at first like it does when it transmits,...
If this is happening to only one number you're trying to fax to, then the problem is most likely on their end, not yours. If it is happening with all the numbers you fax to, then I would suggest checking the telephone line hooked to the fax. Look for loose connections, or perhaps a bad cord from the phone outlet. The connection could be good enough to get a dial tone, but not secure enough for the fax to operate. If none of that holds true, I would suggest taking it to the shop and let a technician look it over.
Oct 23, 2010 | Brother FAX-575 Plain Paper Thermal
Service center contect number in india
You could go to :-
http://panasonic.co.in/web/cid/MainCont/1220
Select fax as product and look for the list of service centers in India.
Good Luck!!
Thanks!!
Aug 03, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Ng poor line condition/ out of memory
Generally this is an indication that the telephone line you are trying to fax over has either alot of noise on it or possibly on the receivers end.If you are on a telephone line which has DSL service on it make sure you have a line filtre connected on the fax to eliminate line noise for your DSL modem, as well if you are using a digital phone service such as Vonage or your Cable providers phone service this is a digital service, contact brother technical support to have your modem speed lowered to 9600bps through the firmware switches on your machine.
Mar 26, 2010 | Brother IntelliFAX 4100 Laser Fax
Scanner not working
A6 is a scan failure detection.
This sounds to me like the motor running the scanner is not working. However, there are three or four causes of this error. The home position sensor, the motor, the CCD, the main board and the engine board.
You should be able to find the sensor that detects the scanner lid. Fool it with a piece of tape or a finger. Look at the scanner after pressing copy to see what is happening.
You could open up the scanner and check the movement to make sure it's smoth, but this is a lot of work. The best option is to pick up a used scanner from a Brother service centre. Install it and see if it solves your problem. Of course, you wouldn't be able to return it if it did not solve the fault. This is why Brother recommended you take it to a service centre, the troubleshooting is very in-depth for a fault of this nature.
Feb 21, 2008 | Brother MFC-8220 Fax
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
