My Flatron L1730S Monitor won't come on until 1:20 pm, as if it's in hibernation mode. I have checked the Power Options in my Control Panel, but cannot find anything.
  • bluey1 May 05, 2008
    Thanks Danmart for the quick response, but unfortunately it hasn't
    helped...it may have something to do with 4 capacitors inside. And that
    is beyond my capacity.
    Thanks again
    bluey1
    Sergeant:
  • 291 Answers
Uninstall drivers in control panel [make sure that u have replacement software drivers] reboot, and see if [I assume] windows will find the drivers.
P.S. the hibernation software is separate program but sometimes reinstalling monitor will reset original program enviorment.
Posted on May 02, 2008
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
I dont have driver flatron l1730s lcd monitor . usb driver monitor
You may be able to download the driver from these WEB sites.
http://totallydrivers.com/device.php?id=74496&show_devs=a
http://www.bravofiles.com/driver-LG-FLATRON-L1730S.html
Apr 06, 2011 | LG L1730SF 17" LCD Monitor
My Toshiba Satellite L305-S5877 will sometimes go into a "sleep" type mode randomly and the screen goes almost completely blank. I can just see what is on the screen very faintly. I checked and...
You have to disable the hibernation mode. Sounds like this is the problem. Go to Start - Control Panel - Performance and Maintenance - Power Options - click on Hibernate tab and uncheck where it says Enable Hibernation. This should fix the problem. Cheers
Oct 02, 2009 | Toshiba Satellite L305-S5877 Notebook
Analog Power Saving Mode Problem!
Have you checked you power saving options in Control panel.
If this is a desktop, unless you are a energy miser, I would change your power saving options to never on all options, turn off hibernation and suspension for when you are playing games.
You can find this in control panel under power Options.
Let me know if this helps.
Thank you
May 18, 2009 | LG 22" FLATRON LCD Monitor
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
Monitor gives recomended settings then puts itself in sleep mode.I cant even get the computer to go into safe mode.
Your computer is in hibernate mode.
Start up your computer and do this
Start >> Control Panel >> Power Options
Select the tab "Hiberbate" >> Uncheck hibernate mode
Also you can adjust there your power setting and monitor settings
Nov 05, 2008 | HP Computers & Internet
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
