Question about Kenmore 54622 / 54624 Side by Side Refrigerator
Kenmore 253.54622406 Problem
My refrigerator was so warm in both side about a month ago, in the first time I could not get any water from the dispenser. Also, so much water was melting from the freezer side as it was so warm. I unplugged the refrigerator and plug it back on the next day, and the problem seemed to be fixed. Last night, I had a similar issue. Both side started getting warm. However, I was able to get water from the dispenser this time. I saw some frost (couple drops of water drops inside the back of the freezer.) So I turned off the refrigerator, and plugged it back in this morning. Finally it started making ice around 4 o'clock again. I read lots of posts and it seemed that there is a defrost problem in my machine. So I would like your expert advice.
Thanks for your help!!
  • 828 Answers
I have had the experience of Moisture in the refrigeration system with some of this brand. If this is your problem it will require a refrigeration tech to recover the charge from the system, change the system drier, evacuate the system to remove air and moisture, then recharge the system with the proper refrigerant.
If your refrigerator is covered by warranty your cost should be minimal. If it is not covered by warranty it can be somewhat expensive. If it is a problem with the defrost system you will see frost build-up on the back freezer wall.
Posted on May 02, 2008
We have a Kenmore Refridgerator in our rental apartment. The light for the water filter went to red. We called the landlord but they claimed that they replaced it 3 months ago. They suggested we hit the...
recommended replacment time is 3 months and the computer knows it was replaced 3 months ago and has counted down the time the reset button was last pressed and determined its been 3 months. Depending on water quality in your region it may not need to be replaced unless the in door water or ice taste funny or the water dispenses slowly through the door because the filter was clogged and having a hard time having water pass through it.
Aug 17, 2011 | Kenmore Side by Side Refrigerator
Our Kenmore Elite fridge mod 596.76252702, leaks about a cup of water on floor, 1-2 times a month
The condensate drain that takes the defrost water out of the fridge is blocked.
Pour some warm soapy water down the freezer drain and this may clear it
Apr 04, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrigerator, model #60267990, serial # EJ5036206, water leaking from the freezer into the fridge on shelves into veggie bins, drain hole freezes up, defrosted it about 2 months ago, and has...
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs. Folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Feb 28, 2011 | Kenmore Refrigerators
I have a bad smell and taste in water and ice from fridge/freezer
Take out all shelves and accessories that can be removed. Wash these thoroughly with a mild detergent (dish washing liquid and warm water) and rinse thoroughly. Allow them to air dry completely.
* Wipe the inside walls of the refrigerator and freezer down completely with a solution of 1 quart warm water and 2 tablespoons of baking soda. Wipe the walls completely dry.
* Leave the doors standing wide open. Use a fan to circulate air through the cabinets for several hours to completely dry the inside walls. After several hours, turn the fan off.
* Replace the shelves in the refrigerator. Place shallow trays of one of the following deodorizers on the shelves of the refrigerator and freezer:
o Baking soda
o Activated carbon (used in aquarium filters, can be obtained at a pet store)
o Cat litter
o Fresh and unused coffee grounds (this may leave a coffee smell that would dissipate after several days)
* After 24 hours, plug in the refrigerator and allow it to cool for several hours with the deodorizer still in place. Once cooled to normal operating temperature, remove the trays of deodorizer and put your food back into the refrigerator and freezer.
* Keep some cereal size bowls of a deodorizer in the freezer and refrigerator cabinets for several days
Feb 28, 2009 | Kenmore Refrigerators
Water dispenser not working. Model 54616.
ok i owuld look at the resevour tank and take a hair drier aand heat up the oiutlet till the water flows again.
Jan 02, 2009 | Kenmore 54613 / 54616 Side by Side...
Warm refrigerator/freezer
very good chance it is the same problem or possibly a leak of refrigerant due to joint failing where compressor is joined to pipework
Jun 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Side by Side Refrigerator 1999
It is normal for that to be warm but not hot. you need to make sure that the condensor coils under the refrigerator is free of dust. You can get to it by removing the back cover and clean it with a vacume. Also make sure the fan at the compressor is operating. and also clean the fan blades while your there. Doing this and making sure the fan is working should solve your problem. Also in the summer time when its hot and humid the refrigerator has to work longer and harder to keep it cold. so you may notice the front just a little warmer then usual, but it should not be hot that you cant touch it. God luck
Jul 09, 2007 | Kenmore 44109 / 44102 Side by Side...
Kenmore 54622 / 54624 Side by Side Refrigerator Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
