Question about Rolex Daytona 116520 Wrist Watch
Rolex ladies DayJust
The second hand is moving properly, but the minute hand will run for about 20 minutes and stopped (while second hand is still running). Reset the time again, and it will run for 20 minutes and stopped. Any ideas ?
My observation, when the crown is unscrewed into the winding position ( first position ), some times the crown will wind free, without engaging any gears, pushing the crown in and out a few times or by turning it continuously, like winding the watch continuously, will cause it to engage.
At times, it seems the crown is not released fully, like not all the way out.
No problem pulling it all the way out to adjust the hands.
Any suggestion is appreciated
  • 2,071 Answers
No problem pulling it the way out its okey,Wind it the crown until calendar move so the hands move properly.When you going back the crown,push the crown hardly going inside while pushing, wind the crown until you reach the end so its locks properly,because has a thread needs to lock so it will not wind freely,that all Working guy, txt me whatever happen.
Posted on Jun 17, 2008
My three-year old (real) Rolex Oyster Perpetual Lady Date Just started losing time after just six months. It would stop and start intemittently and lose a few minutes every hour. Winding did no good. I...
It seems to me that the company servicing your timepiece (Rolex or otherwise) must have missed something or did not properly service your timepiece.
You are correct that your watch should not require service every ten months. After servicing, your Rolex, like most all automatics, should run properly for 3-5 years depending on environmental conditions. Our Rolex service offers a one year warranty, and if any issues present within that time, the service is free.
I would recommend using a company that has a full time Certified Master Horologist on staff to service your timepiece that offers a warranty on their work. Thanks for the rating, and we are happy to help you and service your Rolex.
http://www.watchandpen.com/id76.html
Expert watch repair for Rolex Breitling Tag Heuer Movado
Oct 22, 2013 | Rolex Oyster Perpetual Lady Datejust...
Watch keeps running but cant move hands to set time on rolex datejust
Debbie is the watch definitely genuine?
It is a common fault on fake Datejust's..is the crown completely out?
Mar 29, 2013 | Rolex Datejust SS
How to use the subdials on a wrist watch
One of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Oct 20, 2012 | Rolex SS/18kt Daytona
What are the 3 inner dials for? How do I set them?
one of them is the seconds hand of your watch, this sub dial will keep on moving even if the watch is not used as a stop watch. the other 2 sub dials are for the stop watch function. one is for tracking the minutes and the other is for hours. the big seconds hand will only work if you use the stop watch function. you can reset your stop watch to zero by pressing the pusher located at the 4 o,clock location of your watch.
Nov 09, 2009 | Rolex Daytona 116520 Wrist Watch
Casio Lineage Waveceptor 4717 minute hand off by 20 seconds
You would have to remove the movement from the case, remove the hand and reinstall it, to where you want it.
Aug 06, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Rolex Daytona Chromograph
ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
Apr 26, 2008 | Rolex Daytona 116520 Wrist Watch
Rolex Daytona 116520 will not start
no! you have not done anything wrong my suggestion is bring it to an authorized rolex service center or any certifide rolex watch fixers.to avoid any damage of your rolex daytona. it mabe costly but you have made it wisely.
Mar 10, 2008 | Rolex Daytona 116520 Wrist Watch
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
Setting the time
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Sep 23, 2007 | Rolex Daytona 116520 Wrist Watch
Rolex Daytona 116520 Wrist Watch Logo
330 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
