Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishwasher will not drain water out after completing the rince or final cycle
Dishwasher seems to run and operate normally right up to the drain cycle. The unit sounds as though it is draining but no water is pumped out. This happened to her (it is my daughter's washer) about a year or so ago. They called a repairman who came out, pulled the unit out from under the counter, drained water out with rags and a cup then took off the drain hose - found nothing, not even water, put it all back together and it ran and operated as brand new... We have tried doing the above, but we are not as lucky - nothing drains out. Any assistance will be appreciated.
Thank you!
Rick
Thanks for respsonding, but the problem was a collapsed y-connector at the drain. We think it was an original plumbing error. The clamp was so tight at the connection to the drain, the PVC pipe collapsed. Turns out the problem was six feet away from the dishwasher. Go figure......
Posted on Sep 14, 2008
    Sergeant:
  • 409 Answers
check to see if there is anything stuck in the pump. if there is nothing and the problem persists, have the technician replace the drain pump.
Posted on Sep 13, 2008
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
I have an older GE dishwasher Model # GMB921HB119. The machine operates normally till it reaches what I believe is the final rince cycle and stops. The timer continues to advance, reaching the drying cycle...
Is this machine new to you or have you had it long enough to see it work properly?
If it used to work as it should then you know that there is probably a problem other than your water or soap. If you have whopping lime in your water then the problem could be in a water treatment system (softener, RO system, etc) Is there a screen and is it not plugged when you clean it? Does the machine drain the wash water properly? Does it spray in the rinse cycle?
If the screen is not plugged then it should be able to drain the wash water. If it's draining the wash water then you should get a good rinse if you're not using too much soap. If it's not draining the wash or spraying the rinse then I'd suspect the timer. If it's not draining I'd suspect a plugged screen, a solenoid valve or the timer. If it's not spraying the rinse then it's just about got to be the timer.
lp
Dec 26, 2010 | Maytag Dishwasher
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
The dished appear to have a milky film on them after washed. We we use rince aid but it is not working. How de we get them sparkeling clean ?
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Daniel
Aug 07, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Kenmore dishwasher
The water that remains after the final rinse is normal and serves to keep the seals lubricated. This is a normal function of the dishwasher.
Jun 08, 2007 | Kenmore 17259 Free-standing Dishwasher
Machine blocks at rince cycle
running empty or full makes no difference. problem may be not draining to test this, put some water in appliance from a jug then start the cycle. (first action is to drain) see if water disappears. get back to me if you wish
Apr 02, 2007 | Siemens WXLP1460 Front Load
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
305 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
