Ovens Logo
Posted on Aug 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The beeper on the stove timer came on for no reason at all, and I cannot get it to shut off for good. If I press timer, it will reset back to 1 hour and 59 minutes, but when it goes back to zero, the timer begins to beep again. I have also unplugged the stove, to see if it would reboot itself and the timer just resets to the same time. How do I turn it off so that it stays off?
Anonymous
Level 3:
  • Master 999 Answers
  • Posted on Aug 18, 2010
Anonymous
Master
Level 3:
Answers
999
Questions
Helped
311302
Points
2740
I would inspect the circuit board closely for a shorted component. If visually it appears normal it is likely the control board will have to be replaced. Eric
I have a whirlpool oven which I bought from Ikea a few years ago but at the end of a timed programme the beeper is not going off can you tell me the answer please.
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
2answers
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
I have a frigidaire stove and the timer sets itself at any time of day or night...
You may find the necessary information related to your problem among these manuals Oven service manual download repair manuals installation schematic... Just choose your oven manufacturer and model.
Mar 24, 2014 • Ovens
Zanussi Zob 330: The clock resets itself to 12:00 and makes a buzzing sound after about an hour of resetting the clock to the correct time. What could the problem be and how do I fix it??
The problem is most likely with the Large Rectangle Grey X2 Capacitor on the clock circuit board which needs to be replaced by an appliance repair person or electrician.
From my understanding, although they are self-healing, as they are subjected to power surges they deteriorate and allow less and less current through the circuit until they get to a point where there isn't enough current flowing to firmly latch the relay (which is why there is a buzzing from the relay turning on and off quickly).
My clock was also at the point where there wasn't enough power for the timer beeper, so when the beeper went off it would reset the clock after about half a beep. And if the clock was started at 12:00, when it got to 16:08 it would reset as there wasn't enough power to display all those led segments.
I replaced the 1000uF capacitor, which didn't change anything, then replaced the X2 capacitor and now it works perfectly!
Hopefully that is helpful to someone. :)
Have problem with Maytag CWE 9000 the beeper keeps going off even after you press cancel Code is F1, any idea
likely the problem is a bad control board, aka a clock/timer. Usually F1 error codes do refer to main board or main control error in which you would have to replace the control. You can also try shutting off the breaker for 7 minutes which sometimes does make the control reset but this only works maybe 10 percent of the time due to the F1 error code. If you need the part number of the control message me back your full model number and serial number as well.
Thank you
Rick
Nov 19, 2011 • Ovens
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
1helpful
4answers
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Oven shuts off by itself
Hello
I am also having the same problem http://tvtropes.org/pmwiki/pmwiki.php/Main/IReadThatAs
this is going to help you
Thanks & Regards
May 23, 2009 • Ovens
Stovetop electric ignitor
cheaper , safer to just get in an accredited electrician to fix the problem
why have something that is just a clock
Mar 24, 2017 • Ovens
2helpful
Amana gas stove acf3325ac f2 code
HI The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
PLEASE RATE IT............................
Nov 16, 2008 • Amana Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
