Question about Toshiba 52HM95 52" HDTV Projection Television
52hn95 sucks I have one that I bought in 06 and have replaced 2 lamps at 300 and something a pop. Toshiba is no help and they don't care that this model is junk, oh ya now it is making a loud buzzing noise and the repair man said it is the color wheel and it will cost 800, so after spending 2400 on it I think I'm going to take it to the dump.... Tell your friends not to buy Toshiba
  • 3 Answers
I feel the same way about this model. Never had so many problems with a Toshiba t.v. before. Thank God we bought the service contract!
Posted on Jun 20, 2008
    Problem Solver:
  • 4 Answers
Just needs to be cleaned, it will be like new after
Posted on May 23, 2008
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
My Toshiba 42H83 (2004) has double (or triple) images. Is this something that can be fixed? Is the repair some sort of lamp? If so, is that an easy fix?
This tv have a problems known as a convergence problems,it dead.The tv convergence booard the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board, must be replaced to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 18, 2010 | Toshiba 42H83 42" Rear Projection...
I just heard a loud pop and my picture went to out
the service manual is available in the web site andrewselectronics for sell.
there is a chance to inspect the lamp and see if is damage (normal failure for this popping noise) consult you user's manual ...How to replace the lamp. as i said inspect it and replace it as needed, use original lamp. Toshiba
Feb 23, 2009 | Toshiba 62HM95 62" HDTV
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Jul 15, 2008 | Hitachi 55VS69 55" Projection HDTV
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
Tv help
Google Toshiba 52HM95 Service Manual. There is a site that will download it to you for $11.99. However, the section about removing the light engine is not very good. I tried it with mine and could only get the engine out a couple of inches. It would get caught on some of the wiring where I couldn't find a plug to unplug it. Sorry, but this is a tough one.
May 12, 2008 | Toshiba 52HM95 52" HDTV Projection...
46" toshiba dlp projection picture problems
Take out the lamp and clean it. Look inside where the lamp was and you will see a thin peice of coloured plastic (colour wheel). Vacuum that plastic and all around it but don't touch it. This solution worked for me, and now my TV is as good as new.
Nov 10, 2007 | Toshiba 46HM95 46" HDTV
My set switches from low lamp to bright lamp on its own constantly
I just got mine back from the shop withe a similar issue. The picture would dim especially with dark scenes and you could actually hear the lamp popping and clicking. It was not consistent enough that I had to video tape the issue for the technicians. In short, they decided that the ballast was faulty, unfortunately, the only way to replace the ballast is to replace the entire light engine. The part is about $320 and they also replaced the lamp for $150. The extended warranty would have only covered parts I believe so you may have ended up OK.
Jul 12, 2007 | Toshiba 72HM195 72" HDTV
Orange/muddish color??
Sounds like a color wheel or a light engine problem problem my friend. This set is a DLP type projection set. The light engine part number is 234054 and cost $456.00. Good Luck
Jun 20, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
