Question about Frigidaire FWTBB30DS Front Load Washer
Frigidaire washer starts to fill then stops
Frigidaire front load washer will start to fill,3 or 4 seconds then stops,it will do this a couple of times and it just sits there I replaced the electronic control board,any other help,Thanks Marvin
    Novelist:
    Scholar:
  • 148 Answers
Check the water level fill sensor. Some used to be pneumatic tubes connected to a sensor. Your washer may have a different type of sensor. It seems like it fills ant gets to a point where it expects the fill sensor to trip but instead just stops. Also re check ALL connections to main drive motor.
Also verify your mains power can handle the draw of the rated wattage. When it goes to engage the main drive motor it may not have enough current from the mains and simply stops.
Also check that the connection to the tumbler drum is not frozen.
Posted on May 02, 2008
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
We have a frigidaire front load washer about 3 years old. We moved and has been sitting for about 2 months now. Just tried to plug it in and use it and it will fill with water and stop. Now it's not...
The first thing to check is your water supply lines and make sure there is no sediment build up.You may need to replace the main control board,also check to make sure the drain pump is not block or restricted.
make sure you have the proper voltage to the machine.
Sep 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire Affinity AFT6500GG won't spin or fill up.
Check the hose from the drum area to a fill control valve. It will be a small hose. If it is clogged with lint, the control valve can't work. Try to undo it at both ends and rinse it out.
Apr 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Door lock
Check for loose wires in the door lock; or replace door lock.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidiare washer not doing anything
Before replacing check the voltage to the machine. Make sure the machine is not on any extension cord.when the machine is turned on make sure the voltage doesn't drop more than a few volts.
Oct 05, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FWTBB30DS Front Load Washer Logo
1,074 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
