Question about Logitech QuickCam Communicate STX Personal Web Camera
Just bought please i need help instaulling this i'm have probblem it will go threw everything and stop at usb several messages come up and than a box comes up telling me to type in the file i do that and it still don't work...please i need help ...HELP ME PLEASE .....thank you ...Ethel
  • 156 Answers
Go here to get the newest logictech communicate stx drivers. All you have to do is choose your Operating system and a language and download. Its takes you right to where you need to be. Also leave the Webcam unplugged during the installation until it tells you to plug it in. After the installation is done check the microsoft update website to make sure some newer drivers for windows arent't offered. You can do that by clicking windows update in the tool menu of an open IE window.
Posted on May 02, 2008
    Guru:
  • 147 Answers
If you haven't tried a different USB port, the problem is most likely a defective Camera. It has been known to happen.
Please let me know if this helps. Take care!
-Chimpster
WHERE DO I FIND DRIVER ON LINE TO INSTALL FOR MOUSE
Try the following site for mouse drivers.
Trust this helps, regards Alan
http://www.microsoft.com/hardware/en-au/downloads
If re-installing the driver does not fix the code 43 error, you may like to browse through the following:
Are You Seeing Code 43 Error Here What You Need to Do
Apr 15, 2015 | Computers & Internet
Motorcycle will not exceed more than 20mph
You need to have your carburetors cleaned.
Its sounds like clogged jets.
I saw this several time.
Take carbs off bike, completely dissassemble all the jets from the bowls, take out diaphrams.
Soak everything except the float and the diaphram in a carburetor solution available at your local auto parts store.
Soak the carburetor bodies as well, even if the all don't fit turn them over every hour.
Let everything soak for at least 2 hours, rinse with water, and blow every port and hole in the carburetor bodies out thouroughly, then blow threw all the jets and make sure you can see through them and make sure you can see threw the little holes in the jets.
Once all clean, reassemble, and your bike will run like new.
NOTE: if removing the air fuel mixture screw, turn it in(counting the number of turn) until it stops, once it stops do not over turn it, STOP. now remove it and clean it and replace it. To replace it
turn it in until it STOPS. Then turn it clockwise back to the number turns you counted.
2 turns out is a standard setting to start at.
Dec 01, 2010 | 2005 Hyosung GT 650 S
I Have Toshiba Satellite Laptop, i am continuously getting pop up message " Power Surge On Hub Port " A USB device has exceeded the power limits of its hub port. Please help how to stop this pop...
Remember the help below is only a fix for seeing the error message not for overdrawing the port.
To stop overdrawing the port you need to either use a power supply or a double USB cable.
To prevent seeing the USB Power Surge alert message, complete the following steps:
Click on START, Click on CONTROL PANEL, Double-click on the SYSTEM icon, Click on the HARDWARE tab, Click the DEVICE MANAGER button, Click the "+" next to Universal Serial Bus Controllers to expand the selection.,Right-click and select PROPERTIES on the Intel® USB UNIVERSAL HOST CONTROLLER (not the USB Root Hub),Click the ADVANCED Tab, Check the box that says: "Don't tell me about USB errors"
Nov 29, 2010 | Amstron Toshiba Satellite A80 Laptop AC...
G.E webcam model 98650-1 probem
i think your drivers is wrong you need to downlaod the best driver
i hope i can help you
Sep 03, 2009 | Computers & Internet
Printer cacelling job half way through
Try buying a new usb printer cable, just a thought - could have a dodgy connection.... Also - try a different pusb port on your computer.
Steve
www.yourhandinmine.co.uk
Apr 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
My USB cruzer 4GB has suddenly stopped working
Since you say you have tried on several computers, i am afraid to say your USB is dead, if you have warranty you should take it to the shop you bought it from.
Mar 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Mastercook 9.0
your software has crashed??buy file converter http://www.brothersoft.com/downloads/dll-convert.html
try this site thank you!!!
Aug 06, 2008 | ValuSoft MasterCook Deluxe 9.0: Windows
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Register
I just threw it out. I don't want to spent money on advice. I thought that this was a site for people helping people.
Thanks anyway!
May 06, 2008 | 321studios DVD X Show for PC
Shark iron
I bought this Shark iron last July and I even saved the receipt!!But I threw the box away. The water is leaking out of the bottom. I bought the expensive Rowenta before that, and that one leaked all over my ironing. And I cleaned these irons faithfully every month. I need a toll free number for Shark
Nov 13, 2007 | Euro-Pro Shark GI490 Iron
Logitech QuickCam Communicate STX Personal Web Camera Logo
21 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
