Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
JVC Television 56" in Digital Mode
I need to see how to change my television from Digital Mode to regular televison. It is showing only digital channels at the moment. Do have cable hooked up and can not view it. Please help.
Thank you
  • 78 Answers
Somewhere in the tv's menu there will be something called autotune or channel settings. while in that part of the menu you should find something to change settings. also there are many inputs on the back of big screen tv's, you might try a different input like cable/antenna for instance. it may take a two way splitter to split the signal for both digital cable and analog cable. by next february the analog part of the cable may not work anyway.
Posted on May 02, 2008
Jvc 56 inch television went black, then a large thumping noise, and I tried shutting off the power and could not, so I had to unplug the television; the television now will not come on.
sounds like the WP30 or WP74 series that has a convergence shutdown which will usually cause the thumping through the speakers. Unplug the convergence power board and see if the set will power up. Do not remove the rear cover the board is up front behind the speaker grille. Never remove the rear cover on a JVC rear projection as it can damage the digital circuits due to the safety interlock on various JVC models.
Nov 17, 2011 | JVC Televison & Video
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
2004 jvc 56in projection tv, has sound but no picture
Change the channel to ensure the problem isn't with the current station broadcast. Check the channel at a later time to see if the broadcast problem is resolved.
The type of programming you are trying to watch determines the proper input source. Press the "Input" button on the remote control to change to the proper input source. For example, if the source is a cable or satellite service, press the "Input" button until "TV" mode is selected. A component device, such as a DVD player, will operate on a different input source, such as "Video-1."
Check the coaxial cable, which connects your television broadcast service provider to your television. You need to securely connect the coaxial cable to the "ATSC/Digital Cable In" jack on the back of the television, and the other end to the wall jack. If the cable appears damaged, replace it with a new cable.
If you are using a component device as the source of your programming, ensure the component cables are plugged into the "Video Input" and "Audio Input" jacks on the back of the television or that the S-Video cable is plugged into the "S-Video Input" jack on the back of the television. Connect the other end of the cables to the "Video Output" and "Audio Output" jacks or "S-Video Output" jack on the component device.
Oct 02, 2010 | JVC AV-56WP84 56" Rear Projection...
I have a 56" JVC AV-56WP30. It shows two pics one red and one green. what is wrong and how do i fix it
The LCDs in the tv are in 3 colors, Red, Green and Blue. They are out of alignment. Repair needed.
Aug 09, 2010 | JVC AV-56WP30 56" Rear Projection...
Does it have a built in tunner? src4223@aol
It has an NTSC (analog) tuner. You'll need a digital to analog converter to watch most stations. Low power stations are still available in analog in some areas.
I hope this helps.
May 20, 2010 | JVC AV-56WP74 56" Rear Projection...
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Feb 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Double vision on tv with purple and green colors
This television set, as well as most rear-projections, is prone to convergence driver problems. There are two large chips (STK392-110's) in the TV that need to be replaced, as well as some resistors that are likely damaged as well. Any competent TV repair shops should be able to repair this TV for 200-300 dollars. It is important to note that if the back of the TV is taken off without the proper prep., the Digital input (DVI) will be disabled permanently.
Hope this helps you...
Dec 30, 2008 | JVC AV-56WP74 56" Rear Projection...
Fuzzy blob on JVC Model # HD-56G787
my bulb went out in my 56" jvc hd-56g787 and i need to change it! i have a new buld how do i get to the bulb to change it?????????? thx jimmy
May 26, 2008 | JVC HD56FH96 56" Television
Problem with JVX I'ART 56"
If you go to the following link and leave an email they can get you the remote that you need to operate the set and allthe menu functions and the remote wont need to be programed either. Just leave them an email indicating your model number and they will respond back quickly.
May 24, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
243 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
