Screen is blank unless a flashlight is shown on the screen. Prior to this happening laptop was dropped and the left hinge broke off. Could something else have broken off?
    Sergeant:
  • 291 Answers
"Screen is blank unless a flashlight is shown on the screen"
What happens? The original screen program comes back, For how long? Under what condition does it return blank?
Try something:: While the laptop is on, grab the right * left side of border of screen [The outer rim]. GENTLY.........EVER SO GENTLY...try and twist the screen. Not the hinges, but the screen itself. If the picture comes back, u may have a crack inner board.It can be repaired, if u know what u are doing. If u don't know, don't try it. U can damage *********** board by sending the wrong electricity into it. Your ckt. board could be cracked.
Posted on May 02, 2008
  • 89 Answers
Sounds like the backlight system of your screen is broken. You may have to take it to a laptop repair shop, preferably an authorized service center to have it fixed
Screen goes blank
This is most probaby because of a loose display cable connection .As the cable runs through the hinge slot to the mainboard of the laptop, open the laptop full and try pressing carefully on the left side of the laptop near the hinges area. this should give you the display back.
Mar 18, 2014 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Acer Aspire E1-571-6650 would not charge. Problem thought to be DC Jack (AC Adapter would not fix and DC Jack seemed loose). Had the same problem a year ago in July and it was fixed. Original charger...
Difficult to comment but if a laptop comes in for me to repair and the hinge is broken and maybe cabinet damage, I would offer to replace the broken parts and replace the DC jack, if it was faulty. It is part of the service but may not be cheap to repair!
Hinges usually become loose and very rarely break.
Did the laptop work on the power supply but not on battery?
Feb 24, 2014 | Acer Aspire Computers & Internet
The screen on my daugher's acer aspire netbook will not show icons, etc. unless the screen is positioned "just so". Not exactly the optimal position for working. What is the cause?
The aspire one has a very small video cable running inside the left hinge.
In theory, if the cable is worn out, or even just loose, this could be the cause of the screen going blank.
Nov 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen is flashing occasionally and recently started blacking out
When it is blank can you take an flashlight and shine it on the screen at an angle and see an desktop? If you can then the back lights are failing..If you cann't then its likly the cable that connects the screen to video card. it usally breaks at hinge. Or the connectors are losse..
Feb 24, 2010 | Toshiba Satellite M305-S4826 Laptop
Loose hing on laptop
Unless you are prepared to dismantle the PC yourself you will need to take it to a repair centre or return it to the manufacturer. This is a common problem with laptops, caused by lifting or adjusting the lid by pressure on the screen (lid) near the hinge. The correct way to move the screen is by grasping it at the top - as far away from the hinges as possible.
Unless your laptop came with a faulty hinge I would guess that you are left handed - am I correct?
I can give you instuctions on how to repair it yourself if you want to tackle it.
Feb 12, 2010 | Acer Computers & Internet
Left hinge broke and no screen.
Its possible that there is a cable loose causing a short, which could have happened when the hinge broke.
This would explain why you are not seeing any display. To test if the display is bad, or if the computer is just not working, you can plug in an external monitor. It will help you to see if you nicked the cable, or if the system board is going.
Jul 23, 2009 | HP Pavilion DV9650US Notebook
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
Thinkpad T30 - LCD Not working
I dropped my laptop and screen was verry hard to see unless u shined a bright light at it. the inverter just under the lcd screen happened to come unpluged. I dont know if i was just lucky or if this has happened to more people. I hope this helps some one else.
May 11, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
117 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
