Question about Kenwood DNX7100 Car Video Player
DNX7100 screen stays down
When I put in a cd, the screen stays down. when i turn it off, it does not close when the cd is there, but when i eject the cd and press the V.Sel butten a few times, then it folds up. What is causing this. It did not do that before. it just starting doing that today.
thanks,
zekria
Disconnect the negative cable from your battery for a few minutes, we had the same thing happen when we first bought ours. We found the fix on Crutchfield's website.
Posted on May 30, 2008
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
Mar 19, 2012 | 2008 Honda Odyssey EX-L
My dual model cd770 faceplate will not stay down, I can eject and put new cd's in but I can no longer see the screen behind the faceplate, It drops then the power shuts off and brings the faceplat
No mine did that and what it is is there is a strip connecting the two faces and sometimes it gets stuck and u have to gently pull it out and it fixes the problem worked on mine
Feb 13, 2012 | Dual XD7600 CD Player
My screen will slide down but it will not slide back up after i put a cd in it
maybe it is dirt at the tray..our try to bring it at service center..
Aug 16, 2010 | Kenwood DNX7100 Car Video Player
Numark Axis 8 Problem, does not recognize any CDs
if you are not a tech.have one look at your set.change your lens.or the wire ribon that is attached to the body of the lens that leads to the pc board.if that does not work your micro chip is damage replace the pc board.they cannot be repaired as they are duble solder unless you have equipment to do repair on them.good luck.
Apr 10, 2009 | Nu Mark AXIS 9
Numark Axis 8-Screen says CLOSE, but does not recognize CD
either your set does not recognize the cd or your lens need to be replaced the age of your set has lot to play if it is old satrt shopping for a new set.anyhow have a tech look at your set.a look on the wire ribonthat leads from the body of the lens the pc board will not hurt probably it is damage.good luck.
Apr 10, 2009 | Nu Mark Numark Axis9 Table Top CD Player -...
Kenwood DNX7100 screen won't tilt back up after putting in CD
Yes opening the unit with the eject button then manually closing the unit halfwaly, and disconecting the battery for like 30 secs.... Here
Dec 04, 2007 | Kenwood DNX7100 Car Video Player
DNX7100 - new unit, screen won't power up
It only goes down half way. You have to gently push it down the rest of the way to expose the SD card slot.
Aug 23, 2007 | Kenwood DNX7100 Car Video Player
Screen tilt control problem
Yes opening the unit with the eject button then manually closing the unit halfwaly, and disconecting the battery for like 30 secs cured my issue as well. Thanks
Aug 07, 2007 | Kenwood DNX7100 Car Video Player
Kenwood DNX7100 Car Video Player Logo
162 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
