Question about Canon EOS Rebel G 35mm SLR Camera
Not sure of exact problem
I have had my camera for at the most 2.5 years, and my battery symbol started flashing, so naturally I replaced the batteries, and put in a new roll of film, now when I turn it on to take a picture, it makes a weird sound and the battery symbol starts flashing again. NEW FILM, NEW BATTERIES, it shouldn't do this ugh can someone help me please?
  • 1 more comment
  • sabothell Jul 31, 2008
    I have 2 Cameras, both Canon EOS Rebel G and I have the same problem. I tried 2 sets of brand new batteries on both cameras and they both have the same problem. The camera makes a whirring sound and the low battery symbol flashes. Is this a common occurrence? Help please!
  • JennRaven Dec 03, 2008
    I have the same exact problem as described by previous 2 people. SO frustrating! My camera is only 3 years old and I've spent approx. $1200 between camera and lenses!
  • nhreefer Apr 10, 2009
    battery symbol flashes after new batteries and film also makes a wierd noise
    Genius:
  • 1,689 Answers
The charger may not be charging the batteries properly.
The batteries you are buying may not be good.
There may be a fault in the camera where the voltage is not being properly regulated.
Your best solution would be to take the camera to a camera service center to have everything properly tested to resolve the issue.
Jerry G.
Posted on May 02, 2008
Canon 600ex-rt speedlite won't turn on with new batteries
I was having exactly the same issue with my 600EX-RT. This is what solved the problem for me. With the power turned off. Hold down the 2 clear buttons for approximately 5 seconds, then turn the power on and hopefully, you should have a fully operational Flash.
Apr 14, 2013 | Canon Speedlite 600EX-RT 5296B002 Norman...
I have a Cannon Rebel G EOS was purchased brand new for me quite some time ago. I used the camera a few times and then the battery symbol started flashing stating it needed batteries replaced. I...
Check the batteries on a meter,sounds like they are flat, you can get sold poor battery's as this is an older camera the shops can hold onto old stock, tell me more and i will look into it for you
Apr 08, 2011 | Canon EOS Rebel G 35mm SLR Camera
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
I have a Polaroid t1031 Digital camera that I've only had since last Christmas. It has never been dropped or mishandled. However, the flash no longer works on it? The flash doesn't seem to be physically...
Sometimes the flash will be disabled when the battery is low in order to save power. Charge the battery fully and start up the camera.
At the top of the display, second from the left, you should see a symbol that contains a lightning bolt. This indicates the flash setting. Press the right side of the circular button until the symbol matches the picture on that button (just the bolt, no eye or A or anything). Now the flash is set to forced on. Try taking a picture.
If the flash still is not going off, something is broken. Call Polaroid. They may replace it if you have a receipt (as long as it's not refurbished or over a year old).
Jul 26, 2009 | Polaroid i737 Digital Camera
Won't take picture though I replaced battery.
Even though it was cushioned somewhat the camera took enough damage to jam something. The flashing symbols are a generic error code it could mean the shutter, zoom, film transport, flash, or some combination of these system are not working (sorry but without tearing the camera apart I can't narrow the problem any further)
Nov 05, 2008 | Minolta Freedom Action Zoom 90 35mm Point...
Pictures taking too long, and a lightning bolt symbol appears
Hi, Could you please tell us what camera model this is?
I believe you replaced with new fully charged batteries.
Try changing the memory card. Old defective memory card will delay between shots.
If it still doesnt work, try updating the firmware of the camera.
Hope it helps...
regards,
Sep 20, 2008 | Canon PowerShot A410 Digital Camera
Not turning on
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
Aug 23, 2008 | HP Photosmart 435 Digital Camera
Flash Problems
i have exactly the same problem. i have had the camera for 1year and this started to happen on new years eve. has anyone got a answer to the problem? its been a great camera apart from this problem and would hate to have to buy a new one. thanks
Nov 05, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Low battery indicator
If that camera has a problem, the low battery symbol will flash as a warning to tell you that it is not working properly. Kind of like the "Check Engine" light in your car. It tells you something is not working, but doesn't give you any clue what it is!
Check to make sure the pop-up flash is not sticking down when it is supposed to be popping up. That is the most common cause for that problem. Also, check the shutter blades in the film compartment to make sure they haven't been pushed out of their tracks when you were loading film.
If neither one of those is causing the problem, take it to a local camera repair shop and have them check it out.
CameraRepairs
Apr 02, 2007 | Canon EOS Rebel GII with 35-80 lens 35mm...
Camera will not start properly and lens is out
Leave the camera sitting with no batteries overnight. Then in the morning install ONLY Kodak AA batteries. I had the exact same problem.
Jun 22, 2006 | Kodak EasyShare CX7330 Digital Camera
Canon EOS Rebel G 35mm SLR Camera Logo
192 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
