Question about HP DeskJet 990cxi InkJet Printer
Need help printer problem
Resume Light Blinks and the Carriage is Stuck
  • eecee Dec 25, 2008
    this printer has been  very reliable but now the carriage is stuck - end of the line?
I want hp deskjet 990cxi driver
Posted on Jun 24, 2008
Alarm/power light blinks five consecutive times
A repeating 5 orange flash is supposed to mean a foreign object inside the machine interfering with the print head. Check at both ends or the carriage track for a crumpled up wedge of paper. If nothing is there, check down the back paper feed path. If still nothing, it is possible the print head is overheating and is about to die.
Jan 03, 2018 | Canon PIXMA iP4200 InkJet Photo Printer
Check print cartidge light keep blinking and the light on copies showing empty while there is paper in the tray
Issue: The Check Paper and Check Print Cartridge lights blinkIn this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : On
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : On
  • Color Start Copy light : On
Figure 79: The Check Paper and Check Print Cartridge lights are blinkingc00864299.gif
    hpweb_1-2_minus.gifCauseThe carriage is stalled or jammed. A message indicating that the carriage is stalled might appear on the computer.You might also experience the following symptoms:
    • The product will not print.
    • The carriage is stuck and does not move.
    • The product makes loud grinding noises.
hpweb_1-2_minus.gifSolutionsSolution one: Turn the All-in-One off and then on againFollow these steps to turn the product off and then on again.
  1. Press the On/Resume button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the On/Resume button (c01602202.gif ) to turn on the product.
  4. Check the lights on the control panel to make sure that they are no longer blinking.
  5. Try the intended task again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Make sure that the front panel overlay is installed correctlyIf the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay.If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
Oct 07, 2011 | HP PSC 1210 All-In-One InkJet Printer
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Hp officejet k8600 printer won't print
after going thru this machine, i found cleaning station not working, well, motor is same as those on office jet 7110 series, so if that is problem switch out motors, and test
Mar 01, 2009 | HP OfficeJet Pro K8600 Printer
HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
Oct 06, 2008 | HP DeskJet 1280 InkJet Printer
Paper jam
dear yelly
try this methode
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke,thanks
cropp
Jan 17, 2008 | HP Photosmart 7450 InkJet Printer
Hp deskjet 6980 blinking lights
ok so for this situation you have to do a cold reset, and by this you have to go ahead while the printer is still power on, disconnect the power cord in back of the printer, and wait for about two minutes. power on the printer if printer still has the blinking lights then go to step 2.
step 2-after this check the printer if light are still blinking, then your going to remove all printheads, remove paper, and then unplug printer power cord from printer and also from the wall outlet, wait for 20 seconds, then power on the printer, wait for light to flash then install the printheads, put paper, and press the resume button.
*** always connect your printer to a wall outlet never to a power strip, the power strip robs some of the power from the printer***
and this should fix the problem if it doesnt then the carriage might me malfunctioning . hp recently did a recall on some printer with the 6940 and some of the 6980, that the carriage broken.
Hope this help!
Nov 27, 2007 | HP Deskjet 6980 InkJet Photo Printer
Flashing lights
That flashing pattern is consistent with a stuck carriage. Here is a copy/paste from HP concerning the 5000 series and your flashing lights.
Issue
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Close the cartridge flaps after removing the ink cartridges.
4. Turn the printer off, then on again.
5. Replace the ink cartridges.
6. Close the top access door. Issue
The Resume light continues to blink after the cartridges are released.
OR
The carriage is stuck or makes a grinding noise.
Solution
1. Lift the top cover to the printer.
3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover.
6. Reconnect the power cord to the back of the printer. Plug the power cord to the wall outlet.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Oct 23, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 990cxi InkJet Printer Logo
94 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
