Question about KitchenAid A-9 Electric Burr Grinder
A-9 Kitchenaid grinds slowly and stops
I have taken it apart and cleaned it but it still grinds slowly and gets hot I have bought a total of 4 units 1 for myself and 3 as gifts so far 2 have the same problem
  • 49 Answers
Go to Ebay and buy a old still running after 40 years, original back when made by hobart. they have the square door on the exit spout.
Posted on Nov 14, 2008
Our Miele coffee machine is not grinding the coffee and only delivering water. I have cleaned the brew unit but still no coffee. Any suggestions?
Sounds as if the grinder and or the coffee chute is plugged with grounds, this can happen when using a very fine grind and /or a very oily bean. Sometimes the grinder can be cleared when taken all apart and cleaned with a tooth brush - but this would require a service tech for the most part - have to take quite a bit apart to do this
Oct 30, 2017 | Miele Coffee Makers & Espresso Machines
Kitchenaid frozen bearing
Hi Thaddeus, What model is it? If you have taken it apart and checked the worm gear surely you would have stumbled on the frozen bearing if one exists. When you split the gear cases you are in a position to turn everything by hand so any frozen part is going to be pretty obvious.
Cheers Ross
Apr 24, 2016 | KitchenAid Food Mixers
My Kitchenaid microwave model YKCMS1555RSS-1 continues to run. The microwave will only stop once the door is open or the unit is unplugged. Any ideas what this could be?
One of your three door switches is bad. They are cheap. replace them all. Careful some are normally open and some are normally closed. Don't get them confused or you will get other symptoms like a blown fuse
Dec 30, 2014 | KitchenAid Microwave Ovens
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
Hotpoint dishwasher will not drain
This sounds like the control panel has failed, it is all one unit.
Apr 04, 2017 | KitchenAid 24 in. KUDS01ILWH Built-in...
The top of our Kemore 87042 dryer is getting untouchably hot while drying. We have taken the unit apart and completely cleaned out all of the body and venting but the problem persists. Will a problem with...
Yes if the thermal or high limit switch is bad, it will allow your unit to get way to hot, and just keep producing heat instead of shutting down the burners then lighting then back up and the unit drops down to a lower temperature. I would replace the thermal or high limit switch ( They are the same thing)
May 18, 2010 | Dryers
I took the jar off and cleaned/scraped the port out(the square hole that the gounds come out of) then gently "bumped" the top and side of the unit on newspapers to get the accumulation of 40 years of stray grounds out and it runs great now!!
Apr 09, 2008 | KitchenAid A-9 Electric Burr Grinder
Canon MP530 Makes Grinding Noise when printing starts
I had this same problem and called tech support. Instead of sending a new printer they had me
1 remove print Cartridges
2 remove print head
3 replace print head
4 replace print Cartridges
5 unplug power from the wall
This seemed to fix the problem.....for me anyway.....for now.
hope it helps
Dec 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
KitchenAid A-9 Electric Burr Grinder Logo
444 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
