Hi, I need to reset my Belkin F5d7230-4 router to reconfig the contents. However, I lost my installation cd. Could you pls tell me where can I download it?
If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
It is not likely you will be able to recover the password if the individual who implemented it is unavailable to provide it. Your only alternative is to factory reset the device according to the manual and then put in the necessary settings required. The default username and password for this device is easily found in the users manual for the device, found here:
well all u need to put ur broadband or hardwire cable into wan port of the router and check ur ips if they are on obtain automatically....then try i hope this will work
Go to the Belkin support section at their website: http://www.belkin.com/support/
Look for your model router and download the "firmware" upgrade for it. Once you go install the up to date firmware try to give the router a reset. Hopefully doing all that will get the router working again and you connecting to the Internet.
