Question about KitchenAid KGST307 Gas Kitchen Range
Replace inside oven glass
Glass craked with liquid spill.
  • baygray May 02, 2008
    How much should service cost, can I do it if I get the part.
    Scholar:
  • 58 Answers
You can replace the glass if you are somewhat handy, but this is QUITE a project honestly(very time consuming since you have to disassemble and reassemble the whole door to do it). What i would recommend is taking your model number and going to kitchenaid.com click customer service and enter your model in the Locate manuals sections, if you get no results first remove the final number for example kGST307SS2 remove the 2(you will get what i mean with your actual model, which is located when you roll the drawer out on the actual units frame) if you type in KGST307SS2(remember example model) remove the next letter and so on till you get results. The results you want is Use and Care guide, installation instructions (one of the two usually has how to take off the door but NOT how to disassemble it) and the parts list, now the parts lists usually gives a breakdown of the door and where the parts go(id recommend labeling parts with numbers and taking digital pictures just for reference) also the parts lists will give you part numbers etc...order the glass pieces either by calling Kitchend aid 1-800-334-6889 or usually local dealers can get you the parts.
If you think this is to much most service calls range between 40-100$ depending on area, usually average 60-80 from my experiences. you can use the same tab customer service, then in the locate service provider click major appliance, type in your zip and pick gas range and it will give you everyone in the area.
Posted on May 02, 2008
The sove oven doar had a spill the spill went through glass and now in between the glass and i cannot get to it to clean.HOW CAN I GET THIS GLASS TO CLEAN I DONT NO HOW TO OPEN THE DOAR
The glass in oven doors is not designed to be removed and cleaned. Although theoretically possible, it is not practical to do so.
Nov 15, 2013 | Kitchen Ranges
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Some liquid has gotten spilled between both glass panels. Need to find out how to clean inbetween the glass.
open the oven door and you will see screws in the door, remove them and it will come apart. I did this before, but it has been a while, but I was able to clean.
Apr 07, 2011 | Whirlpool Kitchen Ranges
Everything seems to be working except it won't heat anything it just suddenly stopped heating.
Did anything spill or blowup inside? Remove the glass tray and be sure all is clean and dry.
If something did blow up (food or liquid), find the small mica window on the inside, and carefully remove it, clean up, dry off in the cavity too, and replace it.
Try to use. This has fixed 3 different microwaves for me. Hope it helps you.
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Glass inside oven door.
chuckbr,
You asked, there are no instructions how to manually clean the door glass on the inside of the door.
They sell a range cleaner that is like the type of liquid compound you use for your car.
It's thinner an smoother. Just ask at home store!
it's easy.
bless You,
huuum,
Please give me a solved rating before you sign off
Aug 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KGST307 Gas Kitchen Range Logo
147 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
