I have a ws-a65 big screen and I am trying to disassemble the top from the bottom to move it. I have removed the allen wrench scres on the side but it still does not seem to want to come apart... Any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
There are 4 , pull up
Posted on May 02, 2008
How do I remove the rear axle bearing on a 2000 Chevy 1500 pickup?
You will have to go to autozone to rent a special puller ,,,or make something yourself,, that hooks behind the bearing,, go threw the center hook the bearing and pull it out,,you will need to hammer it out,,, big allen wrench,,, vise grips and a hammer,,, put the allen wrench behind the bearing,,clamp the allen wrench with the vise grips,,hit the vise grips with the hammer,,,work the allen wrench top ,,bottom ,,left side ,,,right side,,, you know move it around to diff places when trying to get the bearing out,,,hope thos helps,,,use a piece of 2x4 wood to reinstal the new bearing drive it in even,,the seal to dont damage the seal
Oct 07, 2014 | Chevrolet Cars & Trucks
INSTRUCTION MANUAL FOR PHOENIX BOOKCASE BED
its not hard.. you need the allen wrench. start by removing the planks (unscrew with screwdriver). then the two side drawers (allen wrench to unscrew, then lift/unhook). should result in all three drawer sections separated plus the 4 connector boards. last is headboard - be careful - top piece with the two small drawers separates from it's stand/part of the headboard. if you cant get someone to hold it still while you uncrew w/allen wrench, just take your time unscrewing and breathe lightly :)
Nov 09, 2013 | Coaster Furniture
I have the front of my 2007 Heriage Classic taken apart, but can't take out the screws on the bottom of the forks. What size allen wrench do I need? The wrnches in my set are either too big or l
Use a long 6mm allen to remove the bolts. Tap the centers of the allen bolts with a hammer and punch to loosen them before removal. I always use a butterfly air tool to remove them. Super easy! You'll want to replace the allen bolts and copper washers when assembling the forks.
Dec 18, 2012 | Harley Davidson Motorcycles
Can you easily seperate the top and bottom of the WS 65807 for moving?
Yes, There are four screws on the sides in big holes under black plastic caps, and then 3-4 screws on the front behind the speaker grill. Check to see if the rear cover will need to be removed too - I don't remember... Take the screen (Fresnel) assembly off first and then the whole top section comes right off. The top weighs the most out of all the parts.
Mar 25, 2010 | Mitsubishi WS-65807 65" Rear Projection...
How do i disassemble my ws-65313 for transport
Good Day,
To disassemble this TV follow these directions:
1). Pull front speaker grill off
2). Unplug the 2 cables connectors in front
3). Remove 4 screws on both sides of cabinet (might have plastic covers)
4). Carefully lift cabinet top until the support tabs clear the bottom cabinet
5). Carefully rotate the cabinet top and place back side on floor ( the mirror is on the top side)
6). Pack/wrap properly with blankets and transport in this manner.
Good Luck and Move, Big Irish.
Dec 02, 2009 | Mitsubishi WS-65313 65" Rear Projection...
I have a Mitsubishi ws-65907 tv How do I take the top and the
There are 4 plastic plugs, two on each side, that cover the 4 screws that hold the top to the bottom. You will need an allen wrench to unscrew. You will have to take off screws from the back panel, and also pull the speaker grille off to unplug the wires going to the control panel when you split in half.
Dec 06, 2008 | Mitsubishi WS-65907 65" Rear Projection...
I have a Mitsubishi Ws-65907 I know it comes apart in two pieces Iwould like to give this TV to my father How do I take apart the top fromt he bottom. Any help thanks!!!
There are 4 plastic plugs (2 per side) that cover the allen wrench screws holding the top to the bottom. You will also have to take screws out of the back and pull the speaker grille to unhook the control panel. After unhooking and unscrewing everything, the tv will split in half.
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Removing door handles
Charlene,
You need to use a small allen wrench. There are small holes on the top and botton side of each door handle and underneath on the right and left side of the freezer handle. Just insert the proper size allen wrench in each hole and unscrew the handles.
Regards,
Ann
Nov 17, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
