I NEED TO DISSASSEMBLE MY gATEWAT CX2726 WITHOUT BREAKING INT... IT WONT OPEN UP AND I'VE FOUND EVERY SCREW I CAN. I NEED A DIAGRAM WHICH SEEMS TO BE IMPOSSIBLE TO FIND.
  • 89 Answers
Please check if there are any screws under the rubber footings, or the brand sticker usually under the device.
Posted on May 02, 2008
How to open the Dremel 4000 black brush cap (without slot) ?
I just encountered the same challenge
I opened the 5 x T15 torx screws, pulled the tool very slowly apart and the black caps poped out together with springs and brushes (whats left of them).
My advice is not to try and pry them out as they will break. The inner "ring" is way too big to pop out without being damaged.
After the tool is opened, you can replace the brushes and carefully position all back and while holding both of the caps on the springs, close the tool and screw it back together.
Hope it helps
May 13, 2012 | Dremel Tools & Hardware - Others
Load between 3 way switches and line entering switch box. Breaker trips when both switches in down position
Test your wires.
Somehow you've got a neutral wire, or ground wire, or shorted wire connected to one of the switches.
Without a wiring diagram, best place to start is identify hot wire from breaker.
There should be only 1 hot wire connected to the switches.
Disconnect the hot wire. Then test hot wire to each other wire and screw terminal. Tester will light up on neutral or ground fault. That will narrow down the suspects.
Open following link for example 3-way wiring diagram:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-way
Aug 22, 2011 | Electrical Supplies
Trying to remove icemaker. One screw found & removed. cannot get icemaker out. seems to be another screw holding it in, but I cannot see what it is
Here are 3 diagrams of the ice maker. The first one is the ice maker assembly, and the second is the ice bin assembly, and the third is the outer fountain assembly.
Diagram 1
Diagram 2
Diagram 3
Feb 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
I need detailed instructions on what cables go where on my new power supply for my Gatewat 700GR desktop PC
I found this detailed instide view on Gateway's support website. I must say that this instructional support site is extremely well put together. Hope this helps. Best Regards, -md
http://support.gateway.com/s/PC/R/3726/3726iv.Gatewat 700GRshtml
Nov 09, 2009 | Gateway 700GR PC Desktop
Yahoo.com login problems
It may be a virus problem.. try this.. go to run.. type "netsh int ip reset reset.txt" without quotes.. And restart your sys and then try.. surely it wont happen any more..
Aug 17, 2009 | Yahoo Mail
HOW TO OPEN cASE
After you remove the stand, there is a metal plate under it which will come out. Underneath that there is one more screw, (the last one). After that, carefully pry the case apart.
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
