We have a combo unit. can't find the lint trap
  • psontag102 Feb 13, 2009
    lte5243d where is the lint trap
  • 172 Answers
I hope you just purchased this unit, otherwise it will be full of lint and probably ready to have mechanical failure. The vent is almost always just inside the dryer door on the bottom of the rim. You should see a small handle or lip that you can pull straight up on. If you send me the model numer I can double check this for you. Good luck I hope this helpled you. Mike Anderson mca0824@aol.com
Posted on May 02, 2008
Some objects have fallen down the lint trap in my Kenmore dryer model 592-99057 01. Do I have to remove the front panel or does the lint trap housing come off ?
I don't find any info on that model number. However in most units the front bottom panel comes off, then you can disassemble the fan housing and lint trap. While you are in there take a vacuum cleaner to the whole under side of the unit. Also be sure to disconnect the power first.
Jan 27, 2017 | Kenmore Dryers
How do I clean lint trap for my washer? Clothes coming out with lint lines.
is this a combo washer/ dryer google make ,model and manual or support
Mar 15, 2015 | Washing Machines
Cannot locate lint trap to fit my wsm2420 sazww washer dryer combo ge parts no will not fit
In the Kenmore equivalent, the lint trap is on the back wall of the interior of the dryer. If GE is the same then you'll see two vents at the back inside, one is the intake (where hot air enters), the other is the outtake, which contains a lint trap. You might have mistaken both for nonremovable vents. But one of them is removable. It should have finger holes or something to grab. Just pull it and it will pop out without difficulty. It's probably a two-piece unit (a grate on the dryer side and a screen on the exhaust side, with a space in between for collecting lint), which snaps or slips apart easily, then you can clear the lint, and then snap or slip it back together and just push it back in place in the dryer.
Jul 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Where does the lin tgo on my LG TROMM Model WM3677WH
Per the LG web site, the combo units are self cleaning. The trapped lint is washed out of the system automatically.
You should pay attention to the "cleaning" instructions for this unit. It is important to keep excessive soap buildup cleared out. Also be sure to use the correct soap - special, low suds.
Oct 11, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Red light on,check filter
Is this a ventless dryer? I.e. a condensing dryer?
If so, there is a filter that filters the lint out of the water in the condensing unit. Check your owner's manual to find out how to service this. It is usually a little door on the front, bottom of the unit.
If it is not a ventless dryer, then the only filter I know is the lint screen.
Good Luck!
Oct 10, 2009 | LG WM-3677HW Front Load Washer / Dryer
Lint problem
You must GRARANTEE full and free ari flow outside of the building. Typically this type of complaint is related to restricted air flow outside of the machine...normally there is lots of lint, and it exits through the filter, but when flow is restricted, lint remains inside.
Sep 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Same Problem.. not able to find the lint filter on EWD1477
Lou, thanks for your answer, but I think that the original question is to do with the 'mysterious lint trap' that is mentioned in the manual but isnt actually a part of the machine (ie, its a typo / incorrectly edited manual - copied from another model)
The thing we are trying to find is the lint trap for the condenser unit, which is not the same as the drain pump/filter/trap on the bottom right of the unit (or, at least, shouldn't be - if it existed).
I think this model has a specially designed condenser unit that somehow cleans itself from the action of the washing clothes (in your next run), and flushes the lint from any previous drying cycles away with the rinse water during the next wash.
To help keep things clean, you could try to dissolve or at least break up any gunk buildup inside your machine (likely if your not using the 95 degrees C wash temp setting) by using lots of concentrated bleach (at max temp). However, this could damage the machine, but in my experience it is OK. I am not a employee of electrolux nor am I a service person :)
Jun 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer
forget dryer ck vent to outside look for kinked or flatened hose behind dryer find out side vent hood and ck air flow to verify vent problem try drying load without hose connected to dryer may get warm and a little dusty in room but worth it to verify fix
May 02, 2008 | GE WSM2420T Top Load Stacked Washer /...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
