DVD plays only in black and white
Hi
I just got a new samsung flat screen TV.  My dvd player is playing only in black and white, the cable tv works fine.  Everything works completely fine except that the dvd plays with no color.  I checked all the settings I could figure out and can't find anything that is set to black and white or anything.  I noticed that the cord going from cable to TV has 3 video plugs (red, blue, and green).  My dvd to TV has only the 1 yellow video plug.  Could this be the reason?
  • 2 more comments
  • btcollins873 Feb 15, 2009
    I have the same problem, only my DVD also has the blue, red and green input connectors and i still get a b&w picture.... any suggestions?
  • Anonymous Mar 15, 2014
    the yellow light stays on for dvd and the tv is blank screen changing colors white,black ,red ,blues,green
  • Anonymous Mar 22, 2014
    I have connecting cords (with yellow, red, white plug-ins, but I'm not successful so far in getting TV (a Sharp LC-205H1U flat screen) to play a DVD on the Emerson DVD/VHS player. I've lost the instruction that came with it.
  • Anonymous Mar 24, 2014
    Don't know what channel the tv should be on or if I have to set something up. This is my 1st flat screen tv. Couldn't find anything in the manual and the remote on tv or cable have no dvd button.
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
  • angeladionne
    angeladionne Jan 26, 2014
    thank you. this solution worked for me.
  • Ellen Lerner
    Ellen Lerner Feb 28, 2014
    The only way I got sound was to put yellow in video slot. White into component slot on TV and REd in the audo read input. If I put it in the component red part I lost the sound. But I get no color.
Adjust your Menu/Settings on your DVD player to "Component"---the you will have color!
Posted on Feb 10, 2010
    Champion:
  • 453 Answers
Yes thats ur problem , those 3 colors are for video only , u need dvd with the same inputs
Posted on May 02, 2008
SOURCE:
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
Dvd is playing movies in black and white
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Feb 26, 2012 | Apex Digital ADV3800 DVD Player/VCR
When I play a DVD, it is in black and White. When I play the tv it is in colour. Can't get the DVD to play in colour!
You have one of several possible problems, ranging from best case scenario to worst case scenario:
A DVD video that is supposed to be black and white - try a different disc.
Some setting on the DVD player is set to monotone - check manufacturer's instructions
A bad set of cables connecting the dvd player to the tv - test a known good set of cables
A bad output on the DVD player - test DVD player with a different TV.
A bad input on the TV - try another input if possible, test TV with a known working video input.
Sep 17, 2011 | Computers & Internet
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
When I connect to my TV it only plays black and white
Try to adjust your PC to NSTC if your TV nstc if your TV is PALCAM try also ajust palcam.
Dec 28, 2007 | Shinco SDP-1720C Portable DVD Player
Televison & Video Logo
2,474 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
